Acid-Base Chemistry in Aqueous Solutions
The discussion focuses on calculating the final hydrogen ion concentration and pH of a solution formed by mixing 400 mL of 0.2 M NaOH with 150 mL of 0.1 M H3PO4. The calculations reveal that 0.08 mol of NaOH reacts with 0.015 mol of H3PO4, resulting in 0.065 mol of unreacted NaOH and 0.015 mol of H3PO4 remaining. The final solution consists of NaOH and H3PO4, and the next steps involve determining the pH using the Henderson-Hasselbalch equation and identifying the resulting acid-base pairs.
  • Understanding of acid-base neutralization reactions
  • Familiarity with the Henderson-Hasselbalch equation
  • Knowledge of molarity and concentration calculations
  • Basic concepts of pKa values and their significance
  • Calculate the final pH using the Henderson-Hasselbalch equation with the given pKa values
  • Explore the three consecutive reaction equations for phosphoric acid neutralization
  • Determine the concentrations of the remaining acid and conjugate base after neutralization
  • Investigate the role of limiting reagents in acid-base reactions
Chemistry students, educators, and anyone studying acid-base reactions in aqueous solutions will benefit from this discussion.
User Name
What are the final hydrogen ion concentration and pH of of a solution obtained by mixing 400 mL of 0.2 M NaOH with 150 mL of 0.1 M H3PO4? pKa's are 2.12, 7.21, 12.32
Henderson-Hasselbach: pH = pKa + log /[a]
0.2 M * .400 L = .08 mol NaOH
0.1 M * .150 L = .015 mol H3PO4
.015 mol of NaOH will be converted into H2O.
.08 mol - .015 mol = .065 mol NaOH
.015 mol H3PO4
I'm not 100% sure what to do after this besides find the molarities and continue on in the same methods but with H2O and H2PO4 -?
Am I headed in the right direction?
Write THREE consecutive reaction equations that occur during phosphoric acid neutralization. Find out how far the neutralization goes (in terms of limiting reagents). After the neutralization ends, what acid and conjugate base pair is present? What concentrations of both?
  • · Replies 20 ·
13K
