Connectedness: Show Y U A & Y U B are Connected
  • Thread starter Thread starter radou
The problem involves connectedness in topology, specifically examining the connectedness of the sets Y U A and Y U B given that A and B form a separation of X \ Y, where both X and Y are connected. The original poster expresses difficulty in approaching the problem despite understanding the relevant definitions and theorems.
  • Participants discuss the definition of a separation and whether the sets A and B need to be open in the context of X \ Y. There is a debate about the implications of relative openness and the conditions under which the separation holds.
Some participants have provided clarifications regarding the definitions of separation and the necessary conditions for the sets involved. There is acknowledgment of the need for relative openness in the context of the problem, and references to specific lemmas in Munkres' text have been made to support these points. The original poster has indicated they found a solution but has not shared the details.
Participants note that the definitions and conditions for separations in topological spaces may vary, and there is a specific lemma referenced that introduces additional requirements for the sets involved in the separation.
radou
This one is giving me serious trouble.
Let Y be a subset of X. Let both X and Y be connected. SHow that if A and B form a separation of X\Y, then Y U A and Y U B are connected.
I know all the basic definitions and theorems from the chapter about connectedness preceding this exercise section, but any way I try it, I don't seem to get anywhere.
Any ideas?
When you say "[tex]A[/tex] and [tex]B[/tex] form a separation of [tex]X \setminus Y[/tex]", what does this mean, exactly? My guess would be what I usually call "[tex]\{A, B\}[/tex] disconnect [tex]X \setminus Y[/tex]", that is, [tex]A[/tex] and [tex]B[/tex] are disjoint (relatively) open subsets of [tex]X \setminus Y[/tex], whose union is [tex]X \setminus Y[/tex]. Is this correct?
Well, partially. According to Munkres, there's a subtle difference:
If X is a topological space, a separation of X is a pair of non empty, disjoint and open subsets U and V of X whose union is X. (This is a definition.)
If Y is a subspace of X, a separation of Y is a pair of non empty disjoint sets U, V whose union if Y. (This is a Lemma)
Note that in the Lemma it is not required for the separation sets to be open.
So, I assume if we're talking about X\Y, which is a subspace of X, the sets in the separation are not required to be open.
That won't work. You need some kind of relative openness hypothesis, otherwise the result is false. Take [tex]X = \mathbb{R}[/tex], [tex]Y = [0, 1][/tex], [tex]A = (-\infty, -1] \cup (1, 2)[/tex], [tex]B = (-1, 0) \cup [2, \infty)[/tex]. Then [tex]A[/tex] and [tex]B[/tex] form a separation (according to the conditions you gave) of [tex]X \setminus Y = (-\infty, 0) \cup (1, \infty)[/tex], but [tex]Y \cup A = (-\infty, -1] \cup [0, 2)[/tex] and [tex]Y \cup B = (-1, 1] \cup [2, \infty)[/tex] are both disconnected.
Also, with the definition of "separation" you cite for subspaces, you can give a separation for a connected subspace, such as [tex]X = \mathbb{R}, Y = [0, 1], U = [0, \textstyle\frac12), V = [\textstyle\frac12, 1][/tex]. That doesn't make sense.
Interesting, it's exactly what says in the book. So, in the "separation lemma" for subspaces, the sets should be open too?
At least relatively open in the subspace, otherwise they are useless for establishing disconnectedness. I don't have a copy of the new edition of Munkres, so I can't guess what he might be thinking there.
I found the solution to this exercise (Ex 23.12)
http://www.math.ku.dk/~moller/e02/3gt/opg/S23.pdf
Consider this problem solved, I'll go through it by myself, although I don't like the looks of it, for some reason.
I posted it if you happen to be interested to look at it regardless.
OK, I looked it up. The problem is that you missed an important hypothesis in the lemma 23.1, which changes things entirely.
Lemma 23.1 of Munkres says that a separation of [tex]Y \subset X[/tex] is a disjoint pair of nonempty sets [tex]A, B[/tex] whose union is [tex]Y[/tex], which satisfy the condition that neither of [tex]A, B[/tex] contains a limit point of the other. This latter condition is exactly what you need for [tex]A[/tex] and [tex]B[/tex] to be relatively open (in fact, clopen) in [tex]Y[/tex]. The examples I gave above do not satisfy the latter condition.
You're right, for some reason I forgot to mention this.
