Thread Closed
Difference between expectation value and probabilty
Share Thread Thread Tools
Oct14-10, 08:46 AM   #1
Psi(x) = Ax -a<x<a
I am trying to find the probability that my measured momentum is between h/a and 2h/a
2. Relevant equations
I have normalized A= sqrt(3/(2a^3))
I know that if I was finding the expected momentum I would use
[tex]\int[/tex][tex]\Psi[/tex] * p [tex]\Psi[/tex] dx
3. The attempt at a solution
so far I have done
[tex]\int[/tex] [tex]\Psi[/tex] * p [tex]\Psi[/tex] dx
with bounds from from h/a and 2h/a
but I know this is the expected value of momentum and I dont think that is the same thing as the probability of momentum.
Could someone please explain the difference in finding the probability of momentum and the expected value of momentum. Or if they are the same thing let me know there is no difference.
Thanks for your time.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Oct14-10, 09:21 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
The probability that the momentum lies between p1 and p2 is not related to the expected value of momentum. The expected value of momentum is the most likely momentum value we'd find in the state [tex]\Psi(x)[/tex]. The probability to find the particle with a given momentum p is [tex] | \psi(p) |^2[/tex], where [tex]\psi(p)[/tex] is the normalized wavefunction in momentum space. To find the probability of finding the momentum in a range of values, we have to integrate this.
Oct14-10, 11:00 AM   #3
Thanks for your help. I converted over to momentum space using a fourier transform then integrated.
Your explanation saved me much time searching.
Cheers!
Thread Closed
Tags
expectation value, momentum, probability
Thread Tools
Similar Threads for: Difference between expectation value and probabilty
Thread Forum Replies
Help with conditional probabilty Set Theory, Logic, Probability, Statistics 8
The Expectation of X and the Expectation of X squared (discrete math) Calculus & Beyond Homework 2
Probabilty of AnB Set Theory, Logic, Probability, Statistics 2
Probabilty Problem Set Theory, Logic, Probability, Statistics 3
what is a probabilty wave? Quantum Physics 2
