Is General Relativity Time Symmetric?
The discussion centers on the question of whether General Relativity (GR) is time symmetric, exploring theoretical implications, mathematical formulations, and potential counterexamples. Participants engage in a technical examination of time-reversal invariance within the framework of GR, discussing various solutions and their properties.
  • Some participants suggest that certain solutions in GR, like black holes and white holes, indicate time symmetry.
  • Others argue that while the equations of GR may be invariant under time-reversal, specific solutions may not exhibit this symmetry due to their dependence on initial conditions or boundary values.
  • There is a discussion about the nature of time-reversal as a smooth coordinate transformation, with some participants questioning whether it qualifies as such due to the lack of smooth transitions in certain contexts.
  • Concerns are raised about how time-reversal affects the metric and curvature tensors, with some participants suggesting that the Ricci curvature scalar remains invariant under diffeomorphisms, including time reversal.
  • Some participants express uncertainty about how to rigorously demonstrate time symmetry in GR, indicating that merely expressing equations in tensor notation may not suffice.
  • There are mentions of spontaneous symmetry breaking in cosmological solutions, which could complicate the assertion of time symmetry in certain scenarios.
  • One participant points out that while equations may be invariant under transformations, specific solutions derived from those equations may not retain that invariance.
Participants do not reach a consensus on the time symmetry of General Relativity. Multiple competing views are presented, with some asserting time symmetry and others questioning it based on specific solutions and conditions.
Participants note limitations in their arguments, such as the dependence of certain metrics on time, which may lead to non-invariant solutions. The discussion also touches on the implications of gauge symmetries and their role in the overall framework of GR.
Phrak
I'm not sure what you mean. Presumably invariance of something under the substitution [itex]t\rightarrow -t[/itex].
I believe some solutions will work if time is reversed, an expanding dust can become a collapsing dust. The theory of the Riemannian manifold specifies that the time component of tangent space basis vector must point in the t-direction. I have no idea if this can be safely reversed.
In short, I don't know, but maybe someone else does ?
Yes it is.
For example, black holes and their time-inverted configurations - white holes - are both solutions of GR.
Yes, relativity is symmetric under time-reversal. The laws of physics in general relativity have the same form regardless of any smooth coordinate transformation whatsoever. Time-reversal is a smooth coordinate transformation.
It occurs to me that I don't know how to show that it is true. Any hints or speculation as to how to proceed?
bcrowell: "Time-reversal is a smooth coordinate transformation."
Hmm... I think I see what you mean here by "smooth" : the mapping of old coordinates to new coordinates is a smooth function.
But I have also heard of parity or time-reversal to not be considered smooth transformations because one cannot smoothly transition from the initial to final coordinate maps by a series of infinitesimal steps (like rotations, or stretching/scaling, etc.).
Anyway, how do we show this more rigorously?
Merely being able to write the equations in tensor notation doesn't seem sufficient, as we can do that for the standard model, but it isn't time reversal invariant.
Under time reversal, the metric g_uv -> g'_uv will change sign on the dx dt, dy dt, dz dt, pieces. This will effect some terms of the curvature, maybe? This looks like it will get complicated. I'm not sure how it will affect the field equations.
Maybe a better place to look is the Lagrangian. Is the ricci curvature scalar affected by a time reversal? There's probably an easy way to see this, but I'm not sure how without the messy method of looking at how it depends on the metric components.
To put it in more formal terminology, the field equations of GR are form-invariant under diffeomorphisms, and time-reversal is a diffeomorphism. Therefore any solution is also a solution under time-reversal.
I claim that it is rigorous, as expressed above.
I think what you've proved is that the standard model can't be written in terms of tensors. That is, I don't think the standard model is diffeomorphism invariant. (It doesn't have general covariance.) If it were diffeomorphism invariant, it would be expressed without a background spacetime; but the standard model is expressed with a certain assumed background spacetime (flat spacetime).
[EDIT] Sorry, this was not quite right. The existence of time-reversal symmetry in the SM doesn't necessarily show that the SM lacks diffeomorphism invariance, because it could be a case of spontaneous symmetry breaking. However, I don't think it's true that the SM has diffeomorphism invariance. For example, whenever you write a derivative with respect to time, that's breaking diffeomorphism invariance; time is treated asymmetrically in quantum mechanics, not as an operator like position.
You don't have to crank through the complete rederivation of the curvature tensors. The curvature tensors change under a change of coordinates according to the tensor transformation laws. Since both sides of the Einstein field equations are tensors, they transform identically, and a time-reversed solution is still a solution.
It's a scalar, so it's invariant under diffomorphisms, including time reversal.
You are probably thinking in terms of the differentiable symmetries of Noether's theorem. Parity is not an infinitesimal transform of the sort that would indicate a differential symmetry, but it is a smooth transform that indicates another kind of symmetry.
So I'm not so sure about this, but maybe I'm missing something. I figure it would be easy to imagine a metric, which is not invariant under t-> -t, (just put some term in the metric proportional to t, for example). As long as the stress tensor is not completely ridiculous, you'd end up with a solution that is not time symmetric.
Equations that are invariant under a certain transformation can have solutions that are not invariant. For example, the equation [itex]x^2=1[/itex] is invariant under [itex]x\rightarrow -x[/itex], but the solution x=1 is not invariant under that transformation. Or consider that Newton's laws are invariant under rotations, but a particle moving along the x-axis in the positive x direction is a solution that is not invariant under rotations.
What you can say is that if a set of differential equations has a certain symmetry, and you find a certain solution under boundary conditions that respect that symmetry, then the solution will have that symmetry as well. For example, this is how we know that the Schwarzschild spacetime is time-reversal symmetric.
[EDIT] Actually this is not quite right, as I realized by asking some questions over in Beyond the Standard Model and browsing WP. You can have spontaneous symmetry breaking. In cosmological solutions, Lorentz invariance is spontaneously broken by the occurrence of a preferred frame (the CMB's frame, or the frame of the Hubble flow). I guess T symmetry is also broken in perpetually expanding cosmologies.
Of course, in such cases the distinct solution you get by applying the symmetry operation to the symmetry-broken state will also be a valid solution if the underlying dynamics respect the symmetry.
But diff invariance is a gauge symmetry, which isn't a real symmetry, is it?
I tend to think of gauge symmetries as redundancies of description.
Certainly at the level of the equations of motion every theory can be made diff invariant, and apparently even at the level of the action http://arxiv.org/abs/1010.2535: "The point here is that any local theory (e.g., a single free scalar field) can be written in diffeomorphism-invariant form through a process known as parametrization"
In Newtonian mechanics, time reversal symmetry means if you reverse time and momenta, the different physical situation obtained is also a solution of the equations of motion. I think Demystifier was giving a comment along these lines, which seems to be different from the diff invariance perspective.
This paper might be relevant: http://arxiv.org/abs/gr-qc/0603087
Take a look at p. 7. They show an example of a heat diffusion equation, which isn't diff-invariant, and definitely not time-reversal invariant. They turn it into a diff-invariant equation, but in order to do that they have to introduce a background field that points in the preferred direction of time. I think the key is that this background field is written as if it were a tensor, but it doesn't transform like a tensor; it's postulated to be constant in its upper-index form.
The field equations of GR aren't like this. They're written in terms of things that really transform like tensors -- no fixed background.
I think diff invariance implies exactly the same thing as what you're saying about Newtonian mechanics.
In the standard formulation of Newtonian mechanics, the laws of physics are form-invariant under time reversal. Therefore any solution can be time-reversed, and it's still a solution.
In the standard formulation of GR, the laws of physics are form-invariant under diffeomorphisms, which include time reversal. Therefore any solution can be time-reversed, and it's still a solution.
I don't think there's anything mysterious or deep going on here. If you write down the tensor transformation law as applied to the rank-2 tensors in the Einstein field equations, they operate in the same way on both sides of the equation, and the only requirement is that the transformation be a diffeomorphism (so that the derivatives appearing in the transformation law don't blow up or fail to exist). The transformation can be any diffeomorphism you like. Time reversal is simply one special case.
This argument only depends on the assumption that everything in the field equations is a tensor that really transforms like a tensor -- not something that's written so as to look like a tensor, but doesn't transform like one.
I agree GR has no fixed background, which is different from diff invariance (or in the language of that paper, diff covariance). But what has no fixed background got to do with time reversal?
Time is absolute in Newtonian mechanics. The time you are referring to seems to be coordinate time, which is not gauge invariant. Is there any formulation using the absolute notion of timelike?
I think you are reading way too much into the ability to write an equation in tensor notation.
I'm not arguing that GR doesn't have T symmetry, I'm merely pointing out that I feel you are overstating what a tensor equation gives us.
This ISN'T enough.
For example, I can write the equations of electrodynamics in tensor notation. I can apply a Galilean transformation to both sides of an evolution equation. And of course both sides still equal each other.
Does this mean electrodynamics has Galilean symmetry? No.
Electrodynamics has Lorentz symmetry, not Galilean symmetry.
I believe the standard model can be written in terms of tensors. Using your limited requirement for "time reversal symmetry", we can apply any coordinate transformation to both sides of a tensor equation, so yes, in that sense (which I feel lacks meaning) it has time reversal symmetry. But the "form" of the equations changed. The weak force instead of dealing only with left handed neutrinos, now only deals with right handed neutrinos.
So I think we are disagreeing on what is even meant by Lorentz symmetry, Galilean symmetry, time translation symmetry, spatial translation symmetry, parity symmetry, time reversal symmetry, etc. which can be worded as coordinate transformations. To me, these mean much more than just requiring equations can be written in tensor notation.
I'm not sure how to proceed. So maybe someone else can suggest a precise definition of "symmetry" in this context.
Gauge symmetries certainly are real symmetries. They are the most fundamental symmetries of the standard model or any field theory. Also, per Noether's theorem they lead to conservation laws, e.g. the U(1) gauge symmetry leads to the conservation of charge.
EDIT: I just realize that I have violated my usual policy of not getting involved in discussions about whether or not something is "real". So I would like to revise my above statement and simply say that a gauge symmetry is a differential symmetry that leads to a conservation law as per Noether's theorem. As to whether or not that qualifies it for status of a "real" symmetry depends on the definition of "real".
Does it make any sense to ask if General Relativity is time symmetrical, or is this an ill posed question?
I could ask the same of the spatial manifold+time of Newtonian mechanics. It makes no sense. Its the stuff that happens on the manifold that may or may not be time symmetrical. (Who asked this ridiculous question in the first place? Oh, that was me...)
I could combine thermodynamics with a curved manifold and come to the conclusion that, no, General Relativity is Not time symmetric. All I have to do is smash two planets together. So this combination doesn't work for temporal symmetry.
But, never fear. We can still ask if the vacuum metric and all it's derivative quantities are time symmetric in Einstein's spacetime manifold.
Secondly, thermodynamics sucks. The world is not a roulette wheel where the value of a function is some obscure value determined by an unknown gambler wasting his life in Monte Carlo. God does not have to play dice to utterly confuse us. We can still leave out thermodynamics and substitute the minutia of particle interaction.
Charge conservation via Noether's theorem comes from U(1) as a global symmetry, not a gauge symmetry.
I don't know the distinction. I thought U(1) was the gauge symmetry.
If you look at that example in the paper, the only way they were able to recast the heat diffusion equation into a diff-invariant form was by writing the field equations with a background "tensor" that doesn't really transform like a tensor. This background points in the forward time direction, and it's the only thing in the field equations that defines a direction in time.
Hmm...you lost me here. It seems to me that the gauge symmetry of GR is symmetry under diffeomorphisms. We don't want time to be invariant under diffeomorphisms, because then it would be absolute...?
The coordinate-independent way of singling out the role of time, as opposed to some other coordinate, is that the signature of the metric is +---, as opposed to, say, ++++ or something. The signature is diff-invariant, by Sylvester's law of inertia. There is nothing in the field equations of GR that prevents us from constructing solutions with signatures like ++++ or ++--. When we look for solutions that have the +--- signature, we are externally imposing a requirement that is not present in the field equations, and that in some sense artificially breaks the symmetry between time and space.
I think there are 2 different things that go by the same name ("U(1) gauge symmetry"). The first thing is a global symmetry gives charge conservation. The second thing is more like a principle of minimal coupling between electric charge and field, so it's analogous to the principle of equivalence which says that matter and spacetime geometry are minimally coupled.
There's a third use of "gauge symmetry", as in Higgs boson and "spontaneous gauge symmetry breaking", which apparently actually means "explicit symmetry breaking", since the gauge (global) symmetry isn't actually "spontaneously" broken. http://www.scholarpedia.org/article/Englert-Brout-Higgs-Guralnik-Hagen-Kibble_mechanism
OK, then I guess my comments refer to the first meaning and I don't know about the other meaning.
But how do we know that there is no theory without prior geometry that isn't time reversal invariant?
But what has the signature got to do with diffeomorphisms or no prior geometry? Special relativity also has Lorentzian signature, but the standard model of particle physics is a specail relativistic theory which isn't time reversal invariant.
A reference which may be useful:
http://prd.aps.org/abstract/PRD/v21/i10/p2742_1
Quantum gravity and time reversibility
Robert M. Wald
The meaning of time-reversal and CPT invariances of a theory is discussed both in the context of theories defined on flat spacetime as well as in general relativity. It is argued that quantum gravity cannot be time-reversal or CPT invariant; that an "arrow of time" must be fundamentally built into the theory. However, a weaker form of CPT invariance could still hold, in which case the fundamental "arrow of time" would not show up in the measurements of observers who perform scattering experiments. Consequences of this weaker hypothesis are explored.
Also interesting, even if not GR-gravity:
http://arxiv.org/abs/hep-th/9307079
White Holes, Black Holes and Cpt in Two Dimensions
Andrew Strominger
It is argued that a unitarity-violating but weakly CPT invariant superscattering matrix exists for leading-order large-N dilaton gravity, if and only if one includes in the Hilbert space Planckian "thunderpop" excitations which create white holes. CPT apparently cannot be realized in a low-energy effective theory in which such states have been integrated out. Rules for computing the leading-large-N superscattering are described in terms of quantum field theory on a single multiply-connected spacetime obtained by sewing the future (past) horizons of the original spacetime with the past (future) horizons of its CPT conjugate. Some difficulties which may arise in going beyond leading order in 1/N are briefly discussed.
If time reversal means taking some coordinate and subjecting it to a transformation [itex]t\rightarrow -t[/itex], then it's a diffeomorphism, and therefore a diff-invariant theory can't distinguish between a solution and its time-reversal. You don't have to say anything about "without prior geometry." If the equations of the theory are written solely in terms of tensors (meaning things that transform like tensors), then it's diff-invariant.
You seem to be saying that Lorentzian signature doesn't imply time-reversal invariance. That's true, but I never said anything to the contrary.
The reason I brought up Lorentz signature was in reply to your post where you asked this: "Time is absolute in Newtonian mechanics. The time you are referring to seems to be coordinate time, which is not gauge invariant. Is there any formulation using the absolute notion of timelike?"
But maybe we're just talking past each other here...?
I don't seem to be understanding what you're saying, and you don't seem to be understanding what I'm saying.
One thing to keep in mind is that GR itself has an extremely high level of symmetry, but that doesn't mean that the matter fields you plug into the stress-energy tensor have that same level of symmetry.
So if the OP asked the question "Is GR time-reversal-symmetric?" (paraphrased), possibly the reason we're all confusing each other is that some of us may be talking about GR itself, whereas others may be talking about GR coupled to some matter fields.
Suppose you want to couple GR to a scalar field that obeys some kind of differential equation analogous to heat diffusion. What's going to happen is that you're not going to be able to write the theory of this scalar field in terms of tensor equations, because the grammar and vocabulary of tensors doesn't allow one to say anything that distinguishes the forward direction of time (in which heat differences even out) from the backward direction of time.
Well, basically I'm trying to understand if Demystifier's and your answers mean the same thing. It didn't seem obvious to me that "time reversal means taking some coordinate and subjecting it to a transformation [itex]t\rightarrow -t[/itex]" , because it's not clear in GR which coordinate is the "time" coordinate. So the definition of time reversal should involve a a diff-invariant quantity in GR, and I thought you were bringing in the signature as the meaning of time in GR.
Yes, I think I confused those two. It's also not clear to me whether I am defining CP violation to be time reversal violation. Do you have access to the Wald article above? Apparently CP violation without CPT violation is not "fundamental" time reversal, whereas CPT violation would be "fundamental" time reversal violation. Apparently Poincare invariance in QFT is closely tied to CPT invariance. Is Demystifier's answer the same as saying that both every [-+++] GR spacetime has a [+---] counterpart which is its time reverse and also a GR spacetime?
Again, I have to object here, because then by that reasoning electrodynamics has Galilean symmetry.
I feel you are reading too much into the ability to write things in tensor notation.
Would you claim the standard model has Galilean symmetry?
Would you claim electrodynamics has Galilean symmetry?
By your argument, anything that can be written in tensor notation automatically has every possible symmetry that we can phrase as a coordinate transformation. I think we need to at least pause and consider: what do we mean when we say a theory has Lorentz symmetry? or time reversal symmetry? etc.
I do not feel coordinate independence automatically yields parity, time, or galilean symmetry. You are equating too many things with mere coordinate independence.
I see. Yeah, that's a very good point that I hadn't thought about carefully enough before.
The fact that the signature is Lorentzian means that locally, you can always define a distinction between two light cones; locally, time reversal means swapping those two light cones. But to talk about global time-reversal, I think you have to assume that the spacetime is time-orientable, meaning that the distinction between timelike vectors in the two light cones can be made in a way that is continuous. Not all spacetimes are time-orientable.
So if your spacetime is not time-orientable, then I guess you definitely can't define anything like a global time-reversal.
I don't think swapping the signature from -+++ to +--- has anything to do with time reversal.
I don't think the standard model can be written completely in tensor notation. There are all kinds of issues there. For instance, time is treated differently than position in quantum mechanics (time is not an operator), and that distinction can't be expressed in tensor language. Raising and lowering indices is done in the SM by using a fixed background metric, which doesn't transform like a tensor.
Well, basically I think electrodynamics does have symmetry under Galilean transformations, but I don't necessarily mean what you think I mean by that. First off, there is the kind of difficulty that atyy was talking about above. Atyy pointed out that the meaning of a global time reversal is not even necessarily well defined in GR, on an arbitrary spacetime. This is even more of a problem when it comes to trying to define something like Galilean symmetry. You don't have global coordinate systems, so you don't necessarily have any clearcut way to define what you even mean by a global Galilean transformation. But in any case, I think it's certainly true that, for example, any electrovac solution of GR is still a solution under an arbitrary diffeomorphism. The electrovac field equations basically make statements about purely topological facts, e.g., that magnetic field lines never terminate at a point, or that electric field lines don't pass through one another. They also relate the fields to the metric, but again only in ways that are diff-invariant. If you give me an electrovac solution that has the global topology of [itex]\mathbb{R}^4[/itex] and is time-orientable, then I can label it with a single coordinate chart consisting of four coordinates (p,q,r,s), where, say, p is everywhere timelike. Then it is certainly true that this electrovac solution is still a solution after I apply a diffeomorphism that takes q to q'=q+kp, where k is some constant. This diffeomorphism does sort of look like a Galilean transformation, if you think of p as time, q as position along some axis, and k as a velocity -- but there is no guarantee that this is really their physical interpretation in any meaningful way.
A secondary issue is that when you refer to Galilean symmetry, you're referring to something that carries a lot more baggage than a simple coordinate transformation. It's a coordinate transformation that is part of a continuous group, with each member of the group labeled by a velocity vector v. Transformations corresponding to v and -v are inverses. There is also the notion that v is related in some specific way to tangent vectors of observers' world-lines. All of these additional notions are separate things that do not follow from diff-invariance.
[EDIT] Corrected an overly broad, incorrect claim about the purely topological nature of the electrovac field equations.
OK, that seems much closer to what Demystifier was saying about black holes and white holes.
  • · Replies 36 ·
  • · Replies 34 ·
  • · Replies 22 ·
  • · Replies 57 ·
  • · Replies 62 ·
