IGCSE: Wire carrying a current in a magnetic field
The discussion centers on the behavior of two wires carrying current in a magnetic field, specifically addressing a scenario where a rigid wire and a flexible wire are positioned with a battery connected to both. The user, Peter, initially believes that the wires should repel each other due to the same direction of current flow. However, the marking scheme indicates that the flexible wire moves towards the rigid wire. The consensus is that when currents flow in the same direction, they generate magnetic fields that attract rather than repel, leading to the movement of the flexible wire towards the rigid wire.
  • Understanding of electromagnetic principles, specifically Ampère's Law.
  • Familiarity with magnetic fields generated by current-carrying conductors.
  • Basic knowledge of circuit components, including batteries and wires.
  • Concept of magnetic field direction and its relationship with current direction.
  • Study Ampère's Law and its implications for current-carrying conductors.
  • Research the right-hand rule for determining the direction of magnetic fields.
  • Explore the concept of magnetic field interaction between parallel wires.
  • Investigate practical applications of electromagnetism in devices like motors and generators.
Students preparing for IGCSE physics exams, educators teaching electromagnetic theory, and anyone interested in the principles of magnetism and electricity.
Peter G.
Basically there is a cardboard with a small hole for a wire and a large circular hole for another wire. Two wires, one rigid is passed through the small hole and another flexible wire is passed through the large circular hole. A battery is connected to both ends of both wires so that the current flows down in both wires. Then, it asks me in what direction will the flexible wire (in the large circular hole) will move to.
I thought that, since the current is flowing down (in the same direction) in both wires then they would repel each other. But the marking scheme says that the flexible wires moves towards the thick rigid wire.
Could anyone tell me why please?
Thanks,
Peter
P.S (First time using this forum, so I'm not sure if my description of the problem is clear and adequate)
It's clear enough
Based on what rules ?
Is it customary of this forum to explain your attempt of solution. Someone will check it.
I didn't understand what you say. I think this is what you mean:
If its customary of this forum to explain solutions... Well I don't know, as I've said, I never used it.
And if you say someone will check it, meaning a teacher, well they are not since I am studying for a test and I'm trying a past paper. I don't have anymore lessons until the day of the test.
Well, I think it is based on the fact that whenever a current is reversed, the field is also reversed. If the current is flowing in the same direction in both wires than they will produce equal magnetic fields that when interact, will repel, not attract.
The reason I put this question here is because I want to know if the marking scheme is possibly wrong. As simple as that. All I need is basically a Yes, you are right, or a no. People don't even need to explain what I got wrong if people don't want to, I will simply research myself if that's the case
