Calcium Sulfate Dihydrate Reaction w/ Water - Fred
The discussion centers on the chemical reaction involving calcium sulfate dihydrate (CaSO4·2H2O) and water, specifically the equation 3 H2O + 2(CaSO4·1/2H2O) → 2(CaSO4·2H2O). To determine the amount of water required for 1 kilogram of calcium sulfate dihydrate, one must first convert the mass to moles, recognizing the 1.5:1 ratio of water to calcium sulfate. The density of water at ambient temperature is 1 g/mL, allowing for a straightforward conversion from grams to milliliters.
  • Understanding of molar mass calculations
  • Familiarity with chemical reaction stoichiometry
  • Knowledge of density and volume conversions
  • Basic chemistry concepts regarding hydration states of compounds
  • Calculate the molar mass of calcium sulfate dihydrate (CaSO4·2H2O)
  • Learn about stoichiometric coefficients in chemical reactions
  • Explore the concept of hydration in inorganic chemistry
  • Study the properties of water, including density and phase changes
Chemistry students, chemical engineers, and professionals involved in material science or hydration reactions will benefit from this discussion.
Mathman23
Hi
I got a question regarding chemical reaction:
3 H2O + 2(CaSO4 . 1/2 H2O) ----> 2 (CaSO4 . 2H20)
calciumsulfat dihydrat reacting via water.
My question is:
If I have 1 Kilogram of calciumsulfat dihydrat how much water is needed ?
Thanks in advance.
Sincerely
Fred
Chemistry news on Phys.org
Hello,
You'll first need to calculate how many moles of calcium sulfate dihydrate are equal to one kilogram. Then notice that there is 1,5:1 ratio between water and calcium compound, just do the necessary math to obtain the moles, and find the grams from it. Since the density of water is 1 g/mL at ambient temperature, you can directly find how many mililiters of water will be used in the reaction.
Hint: one mole of water is equal to eighteen grams, since O:16 g/mol and H:1 g/mol.
Regards, chem_tr
  • · Replies 17 ·
  • · Replies 19 ·
11K
