New Reply
Solve an Equation of Matrices Using Inversions
Share Thread Thread Tools
Oct23-10, 11:06 AM   #1
[tex](C-CB)^{-1}=B^{-1}E[/tex]
Solve the system for B, with the assumption that C,B, and (C-CB) are invertible.
2. Relevant equations
The rules for matrix invertibility (but I've already come to the conclusion that all matrices in this equation are invertible.
3. The attempt at a solution
I attempted to get a solution, but I don't think it's correct:
First I applied the inversion to everything inside the function:
[tex]C^{-1}-C^{-1}B^{-1}=B^{-1}E[/tex]
Then I multiplied both sides by E, to cancel out the inverse on the right side:
[tex]C^{-1}B-C^{-1}=E[/tex]
Then I moved the [tex]C^{-1}[/tex] term to the right-hand side:
[tex]C^{-1}B=E+C^{-1}[/tex]
Finally, I multiplied both sides by [tex]C^{-1}[/tex] to isolate X:
[tex]B=CE[/tex]
This is the solution I got to, but it doesn't seem right. Have I missed anything, made an error in an assumption or calculation, or have I taken a completely wrong direction?
Any help would be greatly appreciated!
Thanks,
Braeden
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Oct23-10, 12:22 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hi Braeden!
Quote by BraedenP View Post
Nope!
1/(3 + 5) isn't 1/3 + 1/5, and it doesn't work for matrices either
(and btw, (CB)-1 = B-1C-1, not C-1B-1)
start again, and try multiplying by something
Oct23-10, 12:36 PM   #3
in such questions, its better to use the rule that :- (A)(A^-1)=I (identity matrix)
Oct25-10, 10:38 AM   #4
Okay.. Thanks, guys -- but for some reason I still can't get it. I can get answers, but none of them are what the solution says is the answer.
The solution first takes the inverse of everything, resulting in:
[tex](C-CB)=E^{-1}B[/tex]
They then somehow jump to:
[tex]C=(C+E^{-1})B[/tex]
That's the step I'm not sure about.. Could you explain that step?
Oct25-10, 11:05 AM   #5
Recognitions:
Hi Braeden!!
it's ordinary algebra …
C - CB = E-1B
so C = CB + E-1B = (C + E-1)B
Oct25-10, 12:05 PM   #6
Quote by tiny-tim View Post
Hi Braeden!!
C - CB = E-1B
Oh! Okay.. I'm just confused about the operations that are allowed on matrices, and which ones aren't.
But that makes perfect sense! Then to isolate and solve for B I just take the inverse of both sides, right?
Oct25-10, 12:07 PM   #7
Guys, lets change the same question a bit. find the solution where no inverse term appears.
Oct25-10, 12:09 PM   #8
Quote by gau_physics View Post
Okay, that just has me totally confused... I don't even know where to begin to now remove the [tex]E^{-1}[/tex] term... I could get it out of the right-hand side, but then I'm going to have CE on the left-hand side..
Oct25-10, 12:13 PM   #9
C=(C + E^-1)B
C=C.B + E^-1.B
C(1-B)=E^-1.B
Multiplying both sides by E^-1 ;
EC(1-B)=B
Is it right ?
Oct25-10, 12:14 PM   #10
Also remember C.E and E.C are not the same.
Oct25-10, 12:16 PM   #11
Its better Braeden that you keep a list of all algebraic operations on matrices and formulae on a page while solving coz matrix algebra is confusing
Oct25-10, 12:32 PM   #12
C=(C + E^-1)B
C=C.B + E^-1.B
C(1-B)=E^-1.B
EC(1-B)=B
Is it right ?
Okay, that's right, but it still doesn't solve for B.. In order to isolate B, I will need an inverse, won't I?
And yeah.. Our textbook doesn't provide a concrete list of allowed operations and rules regarding the operations, so I've been scraping it off of websites and stuff, which could be adding to my confusion.
Oct25-10, 04:34 PM   #13
Recognitions:
Hi Braeden!
Looking back, it occurs to me that this was wrong …
… because the question does not tell you that E is invertible (ie, we're not told that E-1 exists, we'll have to prove that later).
Start again with the original (C - CB)-1 = B-1E,
and get rid of the two inverses by multiplying them out.
Matrices have the usual rules for addition and multiplication, including use of brackets.
They don't have division … you can't divide by a matrix (though, if its inverse exists, you can of course multiply by that inverse, which has the same effect ).
Oct25-10, 06:32 PM   #14
Oh, sorry.. I forgot to mention that, in the previous question, we were asked to first prove that [tex]E^{-1}[/tex] is, in fact, invertible.
And yeah.. I used your method to reach the answer. It worked perfectly! Thanks!
Also, regarding the arithmetic rules:
Basically, addition is easy, but would something like this hold true?
B+C=C+A therefore B=A or is it more complex than that?
Thanks again for all of your help -- I appreciate it!
Oct26-10, 02:51 AM   #15
Recognitions:
Hi Braeden!
(just got up …)
Yes.
It doesn't work for multiplication of matrices, because multiplication isn't commutative (AB ≠ BA), but it works for addition, because addition is commutative (A + B = B + A).
New Reply
Tags
inversion, linear alegbra, matrices, matrix
Thread Tools
Similar Threads for: Solve an Equation of Matrices Using Inversions
Thread Forum Replies
Difficult Math Problem Based on Inversions! Hard! Fun! HELP! Precalculus Mathematics Homework 2
Use matrices to solve the problem Calculus & Beyond Homework 1
How many inversions are there? Linear & Abstract Algebra 0
Dirac spinors under reflections and inversions General Physics 7
How to use matrices to solve systems of ODEs? Differential Equations 1
