New Reply
Side-by-Side Blocks with Force pushing it
Share Thread Thread Tools
Oct23-10, 11:22 PM   #1
Three blocks are in contact with each other on a frictionless, horizontal surface. A horizontal force F is applied to m1. If m1= 2 kg, m2= 3 kg, m3= 4 kg, and F= 18 N, find (a) the acceleration of the blocks, (b) the resultant force on each block, and (c) the magnitude of the contact forces between the blocks.
2. Relevant equations
(a) F - N12 = m1a
N21 - N23 = m2a
N32 = m3a
(b) R1 = m1a
R2 = m2a
R3 = m3a
3. The attempt at a solution
(a) I found that a= 2 m/s2
(b) R1 = 4 N
R2 = 6 N
R3 = 8 N
(c) I have no idea what "the magnitude of the contact forces between the blocks" means. Can somebody please tell me if I've done (a) and (b) right? And how to do (c)?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Oct23-10, 11:52 PM   #2
Recognitions:
Homework Helper Homework Help
Hi ifeelretarded, welcome to PF.
Your part a is correct.
To find the contact force, find the net force acting on each block.
The net force acting on m1 is
F - F1 = m1*a, here F1 is the contact force between m1 and m2.
Similarity you can find tha contact force between m2 and m3.
Oct23-10, 11:52 PM   #3
Recognitions:
Oct24-10, 12:39 AM   #4
Quote by rl.bhat View Post
So F1 was already previously found in part (b)?
Oct24-10, 01:00 AM   #5
Recognitions:
No. R1 is the net force
R1 = 18N - F1.
Find F1.
New Reply
Tags
blocks three
Thread Tools
Similar Threads for: Side-by-Side Blocks with Force pushing it
Thread Forum Replies
A rod with two balls on each side - what do the scales on each side show? Introductory Physics Homework 9
Two blocks on frictionless table, friction between blocks (Blocks side by side) Introductory Physics Homework 2
Magnetic field produced by two side by side wires - when do they cancel? Introductory Physics Homework 10
Death wobble. Uncontrollable side to side movement of wheels. Classical Physics 19
Equation for Object Swinging Side to Side General Physics 0
