Displacement of Water Leaking in a Boxcar
  • Thread starter Thread starter SilentBlade91
    Displacement Water
The discussion focuses on the physics of a boxcar with a leaking water tank, specifically analyzing the displacement of the boxcar after water settles uniformly on the floor. The boxcar measures 7.8 m in length and 2.3 m in height, with an empty mass of 2900 kg and a water mass of 1400 kg. The key conclusion is that, due to the conservation of momentum, the boxcar will experience a displacement to the left as the water shifts to the right, despite the absence of external forces acting on the system.
  • Understanding of conservation of momentum principles
  • Familiarity with center of mass calculations
  • Basic knowledge of physics involving frictionless systems
  • Ability to analyze motion in a closed system
  • Study conservation of momentum in closed systems
  • Learn how to calculate center of mass in multi-body systems
  • Explore the effects of frictionless surfaces on motion
  • Investigate fluid dynamics related to displacement in containers
Physics students, educators, and anyone interested in understanding the principles of motion and fluid dynamics in closed systems.
SilentBlade91
A boxcar of length 7.8 m and height 2.3 m is at rest on
frictionless rails. Inside the boxcar (whose mass when empty is
2900 kg) a tank containing 1400 kg of water is located at the
left end. The tank is 1 m long and 2.3 m tall. At some point
the walls of the tank start to leak, and the water fills the floor
of the boxcar uniformly. Assume that all the water stays in
the boxcar. What is the displacement of the boxcar 9 s after
the water has settled in the bottom of the car (take positive
displacement as being to the right)?
I know I don't have an attempt I am sorry, I really don't know what to do.
I was dumbstruck, too. In reality it wouldn't move, but with zero friction I suppose it would. The water moves to the right, so I suppose the car would move to the left. As a conservation of momentum problem, the car would gain some velocity while the water is moving, then lose it as the water stops. Very difficult to sort that out, though. My instinct is telling me that probably the center of mass doesn't change (no external force so it can't move). So your big picture is
center of mass before = center of mass after
  • · Replies 18 ·
