What was Maggie's acceleration in a 100m race with a dead heat finish?
  • Thread starter Thread starter Freeze
    Acceleration Race
The problem involves a 100 m race where two participants, Maggie and Judy, finish simultaneously, each taking 10.2 seconds. Maggie accelerates for 2.10 seconds to reach her maximum speed, while Judy accelerates for 3.10 seconds. The goal is to determine Maggie's acceleration.
  • Participants discuss the implications of the different acceleration times for Maggie and Judy and how to relate their distances and speeds during the race. Some suggest using kinematic equations, while others question the validity of certain assumptions and the setup of the equations.
There are multiple lines of reasoning being explored, with participants offering different approaches to the problem. Some participants suggest graphical methods to visualize the motion, while others attempt to derive equations based on the given conditions. There is no explicit consensus on the method to be used, but several productive directions have been proposed.
Participants note the potential distraction of Judy's data and question the meaning of certain variables in their equations. There is an acknowledgment that the acceleration is not constant throughout the race, which complicates the application of standard kinematic equations.
Freeze
Ok this is another problem I am having trouble with.
In a 100 m race, Maggie and Judy cross the finish line in a dead heat, both taking 10.2 s. Accelerating uniformly, Maggie took 2.10 s and Judy 3.10 s to attain maximum speed, which they maintained for the rest of the race. What was Maggie's acceleration?
Ok so I know that
Si (initial distance)= 0 m
Sf (final distance)= 100m
Delta T = 10.2s (10-0)
Vi( Initial velocity of maggy and Judy) = 0 m/s
I think Judy's time is there just to distract us, because every time I try to use both set of data and plug them into a kinematic equations for motion with constant acceleration, I reach a dead end.
So I tried a different method
100m - Sf = 1/2 * a * (2.10s) ^ 2
100m - Sf = 2.205A
A = (100m-Sf)/2.205
And Then I tried to plug that back into the SF equatoin but that didn't help.
Can anyone point me to the right direction?
Since the acceleration isn't constant throughout the race, you can't simply use 1/2a*t^2.
So maggie's position would be something like this:
1/2a*(2.1)^2 + vf(10.2-2.1) = 100m
You can find vf by saying vf = a*t where t is how much time she spent accelerating. I hope I didn't give away too much!
So you have
1. Time taken by both to reach the finish line = 10.2 seconds (since this is a dead heat)
2. Distance covered by both in 10.2 seconds = 100m
3. Suppose Vm and Vj are the speeds of Maggie and Judy at any time t, then Vm is maximum at 2.10s and Vj is maximum for 3.10s.
Now draw a graph of Vm versus t and Vj versus t. Find the maximum speed of both Maggie and Judy (given the initial speed = 0 m/s). After t = Tmax--different for Maggie and Judy--the speeds are constant and equal to their respective values at 2.10s and 3.10s. Does that give you some idea how to draw the graph? (If not, the v-t graph has a linearly increasing section followed by a line parallel to the time axis).
Ok so I know that
Okay up to here.
Thats probably because your analysis isn't quite right. And you get equations which aren't too friendly either.
100m - Sf = 2.205A
A = (100m-Sf)/2.205
I don't see what you are doing. Sf has a different meaning here does it? Otherwise, from what you wrote above, 100m = Sf and so each of these equations makes no sense.
Well I think you should graphically do this first, because the solution isn't very difficult and can be done in more than one way. You need two equations for the two accelerations, given the above conditions. Try and rework this after making the graph and follow up with your solution.
Cheers
Vivek
I thought you were saying Sf = 100 m ?
Anyway, like you said, forget about judy.
Split the sprint into two sections : (1) the acceleration , (2) the cruise
What do you know about section (1) ? The time taken, t = 2.1 s. Call the distance s, the acceleration a, and the final velocity v. What equations can you write relating these quantities.
Now for section (2), the distance run is 100 - s, and is run at constant velocity v(accel = 0). You alsko know the time taken for this stretch. Can you not relate 100 - s to v and the time ?
You now have 3 equations in 3 unknowns. Solve them.
Oh sorry with these equations
100m - Sf = 2.205A
A = (100m-Sf)/2.205
I meant Sf = The distance traveled in 2.10 seconds
But I just realized that even if I got the Acceleration from that, It would for after the 2.10 seconds. And I know that anyway. Since after 2.10 seconds they maintained the maximum speed the velocity must be increasing constantly and so the A must be 0.
Ok so that went out the window.
Now the equations that I can relate this three (distance s, the acceleration a, and the final velocity v) are
S = (Vf-vi) * delta t (since vi = 0, it's Vf * delta T )
S = 1/2 a delta t ^ 2
A = Vf * delta T
Now from the info on section 2, now I know that
100 - S = 1/2 a * delta t ^ 2 Or
100 - (vf * delta T) = 1/2 a * delta t ^ 2 or
100 - (Vf (10.2- 2.21) = 1/2 * a * 4.41
100 - (vf (7.99) = 2.205A
100 = 2.205A + Vf(7.99)
100 = 2.205A + A * (2.10) (7.99)
100 = 18.984A
A = 5.27 m/s/s
Yay, Thank you guys for the help.
12K
