Entropy of Schwarzschild black holes
The discussion centers on the entropy of Schwarzschild black holes, exploring the relationship between entropy, mass, and the number of possible states of black holes. Participants examine theoretical implications and the nature of entropy in the context of black holes, including concepts of microscopic and macroscopic states.
  • One participant notes that the entropy of a black hole is proportional to the logarithm of the number of possible states corresponding to the same event horizon.
  • Another participant emphasizes that the only parameter for a Schwarzschild black hole is its mass, questioning how multiple states can exist given this unique parameter.
  • A comparison is made between black holes and macroscopic objects, suggesting that high-entropy objects have many microscopic states for a given macroscopic state.
  • It is mentioned that when a black hole evaporates, its hidden microscopic degrees of freedom may become visible again.
  • One participant references Stephen Hawking's contribution, stating that the entropy of a black hole is represented by the surface area of its event horizon.
  • A participant reflects on the temporal aspect of entropy, proposing that it should account for past and future events influencing the number of microscopic states.
  • Another participant suggests that the microscopic degrees of freedom before evaporation should not be termed "hidden," as they are revealed in the Bekenstein-Hawking entropy.
Participants express varying interpretations of how entropy relates to the parameters of black holes, with some proposing that time and events influence entropy. The discussion remains unresolved regarding the counting of degrees of freedom in gravitating systems and the implications of entropy in this context.
Participants acknowledge the complexity of counting degrees of freedom in gravitational systems and the potential need to incorporate temporal events into the understanding of entropy.
nomadreid
I am trying to reconcile three things:
(1) The entropy of a black hole is proportional to the logarithm of the number of possible states of that object to give the same event horizon.
(2) The only parameter for a S. black hole is its mass, since its electric charge and angular momentum are, by definition, absent.
(3) The entropy of a S. black hole is huge, and definitely non-zero.
So, there are different states for the black hole, but how is that possible, when the entropy is clearly defined by the unique parameter, its mass? I'm missing something elementary here...
Astronomy news on Phys.org
I think the idea here is that parameters like mass (and charge and angular momentum) are like the macroscopic properties of a cylinder of helium: pressure and volume pretty much do it. A high-entropy object is one that has many microscopic states for a given macroscopic state. When the black hole evaporates, its hidden microscopic degrees of freedom will be made visible again.
Having said that, I get the general impression that nobody really knows for sure how to count the degrees of freedom of a gravitating system.
Stephen Hawking showed how the entropy of a black hole was represented by the surface area of its event horizon.
Thank you, bcrowell. In other words, what I did not take into consideration is time: the entropy now depends on events in the future or in the past. Makes sense, so that your definition would have to say "a high-entropy object is one that has, had, or will have many microscopic states for a given macroscopic state."
Also, I guess its microscopic degrees of freedom before evaporation need not be called "hidden", since they are "revealed" in the Bekenstein-Hawking entropy of the horizon. Otherwise one would have to incorporate events with memory into the description.
Chronos: Thanks, this was implicit in my original question, and I was remiss in not making that more explicit. [I do so in my answer to bcrowell to which I answered just before receiving your comment.]
  • · Replies 17 ·
  • · Replies 19 ·
