Probability of a Particle in a box location
The discussion revolves around the quantum mechanics concept of a particle in a one-dimensional box, specifically focusing on the probability of finding the particle in a certain region and various expectation values related to its position and momentum.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the normalization of the wavefunction and its implications for calculating probabilities. There are questions about the coefficient in front of the integral for probability and how to properly normalize the wavefunction. Some participants explore the relationship between the length of the box and the probability calculations.
The discussion is ongoing, with participants actively questioning the normalization process and its relevance to the probability of finding the particle in a specified range. Guidance has been offered regarding the normalization integral and its requirement for the wavefunction.
There is a mention of the need for normalization to ensure the total probability is one, and participants are considering the implications of the box's length on their calculations.
tarletontexan
A particle of mass m is located in a box of length L and found to be in its ground state
A) what is the probability of finding the particle between x=0 and x=L/4
B) What is the expectation value for the position of the particle?
C)What is the expectation value <x^2>?
D)What is the kinetic energy of the particle?
E) What are the 2 possible momentum values for the particle
F)What is the expectation value for momentum
G)what is the expectation value <p^2>?
Probability= the integral from 0 to L/4 of [tex]\psi[/tex] squared, dx
sin^2((pi)x/L)=1-cos(2(pi)x/L)
My attempt at this solution doesn't have a coefficient in front of the integral like my book does in the example it has. I don't know where that one came from and don't know what to put in front of mine for a the book has (2/L) is that like the portion of the box that is being evaluated over? All of the questions above need the question before last to answer starting with the probability. I just need some help getting started and maybe a little more along the way.
It looks like your wavefunction
[tex]\psi = \sin\frac{n\pi x}{L}[/tex]
is not normalized. Something like the coefficient you mention will appear if you normalize this.
so how/where would i begin normalizing that??
You need [itex]\int \psi^* \psi=1[/tex][/itex]
ok so if the particle is supposed to be in between 0 and L/4 then I'm going to get 4/L because it is 1/4 of the total length of the box...
Normalization is the statement that the probability of finding the particle anywhere in the box is 1. That means the normalization integral is over the whole box.
That's a reasonable assumption, try the integration and see if it works out that way.
