What Are the Correct Values of a and b in the Polynomial Problem?
  • Thread starter Thread starter ghostbuster25
The discussion revolves around a cubic polynomial problem involving the polynomial f(x) = 4x^3 + ax^2 + bx + 6. The original poster is tasked with finding the values of a and b given that (x-2) is a factor and that the polynomial has a remainder of -15 when divided by (x+1).
  • The original poster attempts to evaluate the polynomial at specific points to derive equations for a and b, but expresses uncertainty about their calculations. Other participants question the correctness of the evaluations and suggest that the original poster may have misapplied the factor theorem.
Participants are actively engaging with the problem, providing feedback on the original poster's approach. Some have pointed out potential errors in the evaluations related to the factors, while others are clarifying the correct method for determining the remainders when dividing by the given factors.
There is a noted confusion regarding the evaluations of the polynomial at specific points, particularly in relation to the factors (x-2) and (x+1). The original poster's understanding of the factor theorem and polynomial evaluation is being scrutinized.
ghostbuster25
simultaneous polynominals!
stuck on this coursework question
The cubic polynominal f(x)= 4x^3+ax^2+bx+6 has a factor (x-2)
when it is divided by (x+1) it has a remainder 0f -15
find the values of a and b
I did as follows
factor (x-2)
f(-2)
4(-2)^3+a(-2)^2+b(-2)+6=0
equals 4a-2b=26
f(-1)
4(-1)^3+a(-1)^2+b(-1)+6=15
equals a-b=-17
when i solve these it gives me b=17 and a=-8.5
Which i know is wrong
plese tell me where
thanks
I did as follows
factor (x-2)
f(-2)
equals 4a-2b=26
f(-1)
equals a-b=-17
plese tell me where
thanks
You mistakenly found f(-2) when dividing by (x-2)
i thought i was just to put the factor into the equation. Not sure what other way to do. Is the second part correct?
First, divide [itex](x-2)[/tex] into [itex]4x^3+ax^2+bx+6[/tex]<br /> The remainder will have a- and b-terms in it.<br /> But, since [itex](x-2)[/tex] is a factor, that means that it divides evenly into [itex]4x^3+ax^2+bx+6[/tex], so the remainder must be 0.<br /> <br /> In other words, you'll get a remainder of the form ad + be + f (where d, e, and f are integers). Set this term equal to 0.<br /> <br /> Now, divide [itex](x+1)[/tex] into [itex]4x^3+ax^2+bx+6[/tex].<br /> Again, you'll get a remainder with a- and b-terms in it.<br /> Set <i>this</i> remainder to -15.<br /> <br /> You now have 2 equations with 2 variables (a and b) each. Solve the simultaneous equations.[/itex][/itex][/itex][/itex][/itex][/itex]
Yes that is how you do it. You correctly chose to evaluate f(-1) when dividing by the (x+1) factor, but when dividing by the (x-2) factor you incorrectly chose f(-2) to evaluate. What you should be evaluating is...?
I haven't done this in a while, but shouldn't the evaluation of [tex](x+1)[/tex] be [tex]x=-16[/tex], since there is a remainder of -15 when the polynomial is divided by [tex](x+1)[/tex]
What you're referring to is f(x)+1, rather than f(x+1)
Not quite, he is referring to f(x+1)-1
Say you had a root of 2, then (x-2) is a factor and when you evaluate f(2) you will get 0.
  • · Replies 19 ·
