Mechanical Oscillation and Resonance
The mechanical oscillator system resonates at 27Hz when driven sinusoidally with a force amplitude, F(max). At frequencies of 26Hz and 28Hz, the oscillation amplitude is reduced to half compared to the resonance condition. When a constant force F(max) is applied, the oscillator displaces 1mm from its equilibrium position. The governing equation for this system is \(\frac{d^{2}x}{dt^{2}} + 2\gamma\frac{dx}{dt} + \omega^{2}x = \frac{1}{m}F_{external}(t)\).
  • Understanding of mechanical oscillators
  • Knowledge of sinusoidal driving forces
  • Familiarity with resonance concepts
  • Basic differential equations
  • Study the effects of damping in mechanical oscillators
  • Learn about the relationship between frequency and amplitude in resonance
  • Explore the mathematical modeling of harmonic oscillators
  • Investigate the implications of external forces on oscillatory motion
Students in physics, engineers working with mechanical systems, and anyone interested in the principles of oscillation and resonance.
mrmonkah
A mechanical oscillator system is driven sinusoidally with a force amplitude, F(max). The Oscillator resonates at 27Hz. When driven with the same F(max) at 26Hz or 28Hz, the resulting oscillation has half the amplitude as at resonance. When F(max) is instead applied constantly, the oscillator is displaced by 1mm from its equilibrium position.
What will the oscillators amplitude be when F(max) is applied sinusoidally at resonance?
[tex]\frac{d^{2}x}{dt^{2}}[/tex] + 2[tex]\gamma[/tex][tex]\frac{dx}{dt}[/tex] + [tex]\omega^{2}[/tex]x = [tex]\frac{1}{m}[/tex]F[tex]_{external}[/tex](t)
Im finding it difficult to visualise the problem and not so worried about the maths. if you could let me know if i have the right equation in mind, then i can perhaps plug in some numbers a play from there. Other wise i really don't know where to start.
Your equation differs little from this
http://en.wikipedia.org/wiki/Harmonic_oscillator"
