Reaction Rate Order for High Temperature Gas-Solid Reactions
The discussion centers on the behavior of reaction rates in high temperature gas-solid reactions, specifically questioning whether the reaction order can be predicted using stoichiometric coefficients under these conditions. It is established that at high temperatures, the kinetic energy of gas molecules and thermal energy of solid atoms may eliminate activation barriers, potentially leading to local equilibrium. However, it is confirmed that traditional kinetics principles still apply, and experimentation remains crucial for determining reaction pathways and rate-limiting steps. The reference to "Thermochemical Kinetics" by Sidney Benson emphasizes the importance of theoretical frameworks in understanding these reactions.
  • Understanding of classical reaction kinetics
  • Familiarity with gas-solid reaction mechanisms
  • Knowledge of activation energy and reaction barriers
  • Basic principles of thermodynamics
  • Research "Thermochemical Kinetics" by Sidney Benson for insights on reaction pathways
  • Explore high temperature gas-solid reaction mechanisms in chemical engineering
  • Investigate experimental methods for determining rate-limiting steps
  • Study the impact of kinetic energy on reaction rates at elevated temperatures
Chemists, chemical engineers, and researchers interested in reaction kinetics, particularly those focusing on high temperature gas-solid interactions and the implications for reaction order determination.
uby
Hello chemists!
In the classical treatment of reaction kinetics, the overall reaction rate is usually written as a constant times the concentration of species raised to some power (called the order of reaction for that species). It is impressed in high school level students that this reaction order is experimentally determined and cannot be divined by reaction stoichiometry, the reason being that the rate-controlling elementary step does not always involve species in the same stoichiometries (nor even the same species showing up in the overall reaction!).
However, I am wondering if this begins to break down as one considers high temperature gas-solid reactions. I would like to believe the following is true: At high temperatures, the kinetic energy of gas molecules and thermal energy of atoms at the surface of the solid are quite high and it is can become reasonable to assume at high enough temperatures that no activation barriers exist for any chemical reaction (i.e. - that a complete local equilibrium of all species can occur and there exist no kinetic barriers due to chemical reaction). Thus, there may be no "slow" step at all, and the overall reaction stoichiometric coefficients may be used to predict the order of the reaction.
Does anyone know this to be the case? Or, and especially if you know this to be false, if there are any theories out there discussing order of reaction at high temperatures?
Thanks!
Chemistry news on Phys.org
As far as I know kinetics at high temperatures doesn't differ from kinetics at low temperatures - that is, numbers are different, reaction pathways are different, but everything else holds.
It's possible to theorize reaction pathways/kinetics and thermodynamics does put a strong constraint on them (look at a book called Thermochemical Kinetics by Sidney Benson). However, when you have to decide between several logical pathways for how a product could form, experimentation is really the best way to determine it.
As far as the "slow" step goes, it's simply slower than all the other steps in the reaction. Experimentally, it's only possible to observe the rate limiting step. Whatever happens afterward does not affect the reaction rate appreciably.
That's an interesting question, though: if all reactant molecules had enough kinetic energy AND that only one reaction pathway were possible (otherwise, they could react in any way!), would it be possible to observe a rate-limiting step?
  • · Replies 131 ·
11K
12K
