Why does red light travel faster than blue light in glass or water?
  • Context: Undergrad
  • Thread starter Thread starter Pranav Jha
    Light Speed Water
The discussion revolves around the speed of red and blue light in water and glass, exploring the relationship between light wavelength, refractive index, and absorption characteristics of these media. Participants examine how these factors influence the bending and speed of light in different materials, with a focus on the implications of natural frequencies and dispersion.
  • Some participants suggest that red light travels slower in water than blue due to the natural frequency of water molecules being more similar to red light.
  • Others argue that the refractive index determines how much light bends, with blue light bending more in prisms due to its higher frequency being closer to the natural frequency of glass molecules.
  • A later reply questions the concept of natural frequency in relation to water, suggesting that it may not be a relevant factor.
  • Some participants highlight that absorption characteristics differ between red and blue light, with red light being absorbed more in water, potentially affecting its speed.
  • There is a discussion about how the index of refraction is influenced by absorption, with some asserting that absorption does not directly affect the speed of light at specific wavelengths.
  • One participant mentions that the relationship between absorption and refractive index is complex and varies across different wavelengths, particularly in the UV and IR regions.
  • Another point raised is the existence of materials with negative dispersion, where red light can be bent more than blue under certain conditions.
Participants express differing views on the relationship between light speed, refractive index, and absorption in water and glass. There is no consensus on whether red light travels faster or slower than blue light in these media, and the discussion remains unresolved.
Participants reference various absorption spectra and the complexities of dispersion, indicating that the discussion is limited by the nuances of material properties and the specific conditions under which light travels through different media.
Pranav Jha
which light travels faster in water: red or blue? i think the natural frequency of water molecules is more similar to red light than blue. So, the optical density of water for red light should be greater than for blue light contrary to that of a glass prism. I believe red light travels slower in water than blue
But everywhere i have found glass and water treated in the same manner. So, i am not sure any longer.
Please clear my doubt
Science news on Phys.org
Which wavelength is bent most by a prism (hint find a pink floyd album)
The higher the refractive index, the more light is bent.
i am referring to the comparison between glass and water! i think the two cases should be regarded separately based on the natural frequency of light and glass
Get a Pink Floyd anyway!
As NobodySpecial pointed out, higher the refractive index, more the bending. For both glass and water (and I'm guessing, for any medium with positive Refractive index), the order of decreasing/increasing refractive index is same, so both with show similar dispersion pattern.
blue light bends more in prism than red because the frequency of blue light is more similar to that of natural frequency of glass molecules and thus the resulting velocity for blue light is smaller and thus the greater refraction
however, i think, the natural frequency of water molecules more closely resembles that of red light than blue light. So, shouldn't the refraction for red light be greater than blue light in water?
http://upload.wikimedia.org/wikipedia/en/7/72/Water_absorption_spectrum.png
Note the log scale. There is a lot more absorption in the UV than in IR. This is actually very typical for most materials. It's far easier to excite transition with high energy photon than low energy photon. Hence the fairly universal tendency of transparent media to have higher refraction index in shorter wavelengths.
for glass there is a lot more absorption in the UV than in IR However, for water there is a lot more absorption in the IR than UV. so, red light, which closely resembles IR in terms of frequency is surely slowed down more than blue
so, doesn't that play an important role in refraction of visible light ?
which is more likely to force water molecule to resonate: blue or red?
Look at the absorption spectrum that K^2 posted - it shows the absorption of water. In water, there is much more absorption in UV than IR, which disagrees with your statement.
okay, i got that fact wrong
so, the absorption in UV is followed by absorption in IR. Keeping that in mind, isn't it confusing that light absorbs red light more than blue light?
No. Again, look at the graph. The visible light is near the 1μm mark. In that region, if you move towards the red absorption increases, and as you move towards blue, it decreases. But a bit after you cross into UV, absorption starts to increase rapidly. We do not normally observe that bit because we cannot see far enough into violet, but it has effect on the index of refraction.
so: absorption for red is greater than blue. So, when light is traveling through water, red tends to get absorbed more than blue. Thereby, the speed of red light should be slower in water than blue light contrary to that in glass, right?
No. Speed of light doesn't depend on absorption at that specific wavelength. It's the effect of resonances on all possible wavelengths.
So yes, red is absorbed more, but no, it's not slower.
isn't it red absorbed more because it's frequency matches one of the resonant frequencies?
No. If it actually matched, you wouldn't be able to see red light under water at all. It's simply closer to one of the absorption peaks in IR. But there are significantly more strong peaks in UV overall, even though they are slightly further away. So they still end up determining index of refraction.
Edit: Here, take a look at this graph. The blue line is index of refraction. Red line is the absorption. If you go far enough into IR, the absorption in IR starts to dominate index of refraction behavior, and you can see it increasing. But in visible spectrum, UV still dominates. Index of refraction increases as you reduce the wavelength.
People seem to forget that the higher the refractive index, the slower the light is traveling. Red light is bent less than blue, therefore blue goes somewhat slower than red and IR goes faster than UV. The absorption issue is another story. IR will get there first in any race underwater and UV will be the slowest.
so why does red light travel faster than blue light in glass or water? what physical phenomenon is at work in slowing the two lights to different speeds
It's complex and not easy to calculate from the material properties.
There are even glasses with negative dispersion where the red light is bent more in some circumstances - this let's you create optical fibres where neither light is slowed more than the other and a pulse is unchanged over very long distances.
If you want to look it up - it's called dispersion - but understanding it involves knowing a lot about real and imaginary group and phase velocities, there isn't a simple answer
  • · Replies 18 ·
  • · Replies 31 ·
  • · Replies 19 ·
