Gravitational effect on planets when
  • Context: Undergrad
  • Thread starter Thread starter Hyperreality
    Gravitational Planets
The discussion revolves around the hypothetical scenario of the Sun becoming a black hole and its effects on the orbits of the planets in the solar system. Participants explore the implications of such a transformation, including gravitational influences and the relationship between mass density and gravitational fields. The conversation touches on theoretical aspects of gravitational physics and the fate of the solar system over astronomical timescales.
  • Some participants propose that if the Sun were to become a black hole, the planets would continue to orbit as usual, with no alteration in their trajectories, except for effects caused during the Sun's collapse.
  • Others argue that the gravitational field of a black hole does not depend on how mass is distributed at large distances, suggesting that the orbits of planets would remain unaffected at those distances.
  • A participant questions whether the density of a mass is independent of the gravitational field it produces, indicating a potential misunderstanding of gravitational principles.
  • There is a discussion about the possibility of objects being pulled into a black hole even if they are outside the event horizon, with some clarification on the nature of the event horizon itself.
  • One participant mentions that the Sun will not become a black hole due to insufficient mass, instead predicting it will expand into a red giant and potentially engulf the inner planets.
  • Another participant humorously suggests urgency in colonizing other solar systems, referencing the timeline for the Sun's transformation.
Participants express differing views on the fate of the planets if the Sun were to become a black hole, with some asserting that orbits would remain unchanged while others emphasize the Sun's inability to become a black hole. The discussion contains multiple competing views and remains unresolved regarding the implications of the Sun's transformation.
There are limitations in the discussion regarding assumptions about the Sun's mass and its evolutionary path, as well as the implications of gravitational fields at varying distances from a black hole. These aspects are not fully explored or agreed upon.
This discussion may be of interest to those exploring astrophysics, gravitational theory, and the long-term evolution of stars and planetary systems.
Hyperreality
If the sun becomes a black hole, all the planets in the solar system will stil be orbiting the sun as usual, but would there be any alteration in their orbit trajectories? And would the gravitational influence be stronger on the planets?
If so, what is the relationship between the density of a mass and its gravitational field?
Astronomy news on Phys.org
No. that is what people mean when they say the planets will continue to orbit "as usual", the orbits will unnaffected except by the gravity waves and other effects that were caused while the Sun was collapsing.
This can't possibly means that the density of mass is independent of the gravitational field of the body right?
And another question, is it possible for objects to be sucked into a black hole if it is not in the event horizon?
At large distances from the black hole, the gravitational field doesn't care whether the mass is distributed in a sphere of finite size, or a singularity. So, it would be business as usual for the orbiting planets. Closer to the black hole, the increased density will of course result in much larger gravitational fields.
The black hole's gravitational field extends beyond the event horizon, so objects will still get pulled in. The event horizon is a mathematical construct representing the "point of no return" for an object caught in the hole's pull. Once an object moves within the event horizon, its escape velocity exceeds the speed of light, which is why nothing can escape (even light itself).
Originally posted by mmwave
Yes, but on the way to becoming a black hole won't the sun first swell to be a red giant and probably take out the planet Mercury?
That's got to hurt.
Technically, the sun will never become a black hole. It lacks sufficient mass to make this transformation.
Once it exhausts it's supply of hydrogen, it will begin to collapse. This will once again increase the pressure and temperature, which will cause the star to expand once again, becoming a red giant. The diameter of the new star will easily extend beyond the orbits of Mercury and Venus, and possibly even the Earth itself. Even if it doesn't get that big, the star will be much closer to us, and have a greatly increased luminosity. Ultimately, this will probably burn off our atmosphere, evaporate any water on the surface, and increase the surface temperature dramatically, making Earth uninhabitable. Luckily, this won't happen for many many millions of years.
A long time after that, the sun will have exhausted all of its fuel. The outer layers of gas will be expelled, leaving only the collapsed core. At this stage it is a white dwarf star.
Millions?!
I thought it was billions! We'd better hurry up and get to colonizing other solar systems. Btw, I heard that the sun would balloon up and swallow all the inner planets, and probably take some of each with it as it shrinks.
You're right, I meant to say "many many billions". Either way, you and I will be long gone when it happens! :wink:
Maybe YOU will be gone when it happens :-)
  • · Replies 86 ·
9K
