Calculating PV Panel Area and Installed Power for 3000 kWh/year Production
  • Thread starter Thread starter readaynrand
The discussion focuses on calculating the required PV panel area and installed power for a solar energy system aimed at producing 3000 kWh/year. To achieve this, a PV panel area of 27.15 m² is necessary, based on a global irradiance of 850 kWh/m²/year and a conversion efficiency of 13%. Additionally, the installed power required is determined using a conversion rate of 850 kWh/kWp/year, which is essential for understanding the system's capacity.
  • Understanding of solar energy concepts, including global irradiance and conversion efficiency.
  • Familiarity with photovoltaic (PV) panel specifications and performance metrics.
  • Basic knowledge of energy production calculations in kilowatt-hours (kWh).
  • Ability to interpret and apply formulas related to area and power in solar energy systems.
  • Research the calculation of PV panel area using different global irradiance values.
  • Learn about the impact of conversion efficiency on solar energy production.
  • Explore the relationship between installed power (kWp) and annual energy production (kWh).
  • Investigate various PV panel technologies and their efficiency ratings.
Solar energy engineers, renewable energy students, and anyone involved in designing or optimizing photovoltaic systems for residential or commercial applications.
readaynrand
a) What is the PV panel area needed to produce 3000 kWh/year when the global irradiance is 850 kWh/m^2 year, and the conversion efficiency is 13%?
b) What is the installed power in kWp that the PV panels must provide, assuming a conversion of 850 kWh/kWp year (kilowatt hours per year per kilowatt peak rating)?
2. The attempt at a solution
a) Easy peasy, A=27,15 m^2
b) No idea what I'm asked to do here... What does the p stand for?
Please describe the process you learned in class for addressing the problem.
