What Angle and Velocity Are Needed for a Cannon to Hit a Falling Target?
The problem involves determining the launch angle and minimum velocity required for a cannon to hit a falling target. The cannon is positioned a horizontal distance from the target, which is dropped from a certain height. The context is rooted in kinematics and projectile motion.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to calculate the time for the falling target and uses kinematic equations to find the necessary velocity and angle. They express uncertainty about the algebraic approach required and the clarity of their method.
  • Participants question the distance between the cannon and the target, seeking clarification on whether it is represented as dx.
  • Suggestions are made to express the vertical position as a function of horizontal distance and to derive relationships between the components of velocity.
The discussion is ongoing, with participants providing various suggestions and approaches to the problem. Some guidance has been offered regarding the relationships between the components of motion, but no consensus has been reached on a specific method or solution.
The original poster is required to use only the five kinematic equations and their projectile equivalents, which may limit the methods available for solving the problem. There is also uncertainty regarding the interpretation of the term "algebraically."
dekoi
A small cannon (angle manipulative) produces an unknown force on a bullet. Simultaneously, a plate is dropped from h`1 . The cannon is d`x away from the target's horizontal location. What angle is needed, as well as the minum velocity, for the bullet to hit the falling target before its impact with the floor h`1 below. this is similar to this animation: http://www.glenbrook.k12.il.us/gbssci/phys/mmedia/vectors/mz.gif
I am told that i have to do this "algebraically", using ONLY the 5 kinematic equations (and their projectile equivalent) in order to prove the launch angle. You can only use dx, dy, and h in these equations (and i am guessing variables such as g are also allowed).
I am not sure what is meant by algebraically (specifically); although my method seems awkwardly long, yet i am guessing it would work.
firstly, i calculated the time needed for the object falling vertically to fall (square root: 2h/g = t). I used that equation along with vx = dx / t, to figure out the minmum horizontal velocity. v2x = v1x.
dy = v1y(t) + 1/2gt^2 .
Method 1:
0 (d2y-d1y = 0) = v1xtanX(t) + 1/2gt^2
Rearrange to solve for angle X.
Method 2:
0 = v1tsinX + 1/2gt^2
Rearrange for X.
Im not really sure about this. I am in deep fatigue and can't think correctly. Anyone willing to help out?
Thank you.
bump!
I'm sorry, but i haven't heard the policy against or for 'bumping'. Would anyone mind informing?
Does anyone have any advice?
what is the distance between the canon and the target ??
is it dx ?
marlon
You are right on the x-component of the velocity. It is dx/t and t = sqrt(2h/g).
But are you sure the difference between target and source is dx?
marlon
For the Y-component just write y as a function of x. Just substitute the t-variable in the equation for y by t = x/v_h with v_h the horizontal velocity of the bullet at t = 0. Then calculate the derivative of y to x and after you substituted the distance between source-target just solve this equation for the y-component of the velocity...
The angle is tan(X)=(v_y/v_x) y-component devided by x-component of the velocity.
This is just a suggestion. There are other ways to solve this question. I suggest you also try the other ones...for eeuuhh fun...
marlon
  • · Replies 21 ·
  • · Replies 23 ·
