Dipole in physics and Chemistry
The discussion clarifies the concept of dipole moments in physics and chemistry, emphasizing that the dipole vector conventionally points from the negative charge to the positive charge. Simon raises a question regarding the apparent contradiction in organic chemistry literature, which states that the dipole goes from positive to negative. Marlon explains that this is a matter of convention and highlights that dipoles arise from charge distribution differences, particularly in scenarios involving electrodes and charged particles. The formula for the dipole moment, P = Qd, is confirmed to be accurate, with 'd' representing the distance vector from negative to positive charge.
  • Understanding of dipole moments in physics
  • Basic knowledge of charge distribution in chemistry
  • Familiarity with the formula P = Qd
  • Concept of electronegativity and its effect on molecular structure
  • Research the concept of dipole moments in different molecular geometries
  • Study the role of electronegativity in determining molecular polarity
  • Explore the applications of dipole moments in electrochemistry
  • Learn about the behavior of charged particles in electric fields
Students and professionals in physics and chemistry, particularly those studying molecular interactions, dipole moments, and charge distribution phenomena.
Simonnava
Here is my concern,
In my physics class I learned that a dipole moment always goes from the - charge to the + charge. But as I was reading my Organic Chemistry book, it says that the dipole goes from + to -! how can this be?
P = Qd
Does anyone know about this?
Simon
A chemical dipole is the vector resultant of the vectors of the charges present. For example, a V-shaped molecule such as water has two charge vectors pointing from each hydrogen to the central oxygen because of the oxygen's higher electronegativity; therefore, the resultant dipole points straight through the oxygen (bisects the smaller angle between the two bonds with hydrogen). Not sure about physical dipoles or that formula. Hope this helps.
Simonnava said:
Here is my concern,
P = Qd
Simon
This is convention. Mostly a dipole vector goes from - to +. Now what your chemistry book is trying to say is that a dipole arise because the + and - charges are not homogeneous. For example when two electrodes are placed into a neutral specimen containing charged particles (both + and - charges) then when a current is applied for example the positive charges will evolve to one side (or plate if you will) of the electrode and the negative charges will go to the opposite direction. because of this new "configuration" the charges are placed into two groups : a positive group on the one side and a negative group on the other side. this difference in charge distribution causes the dipole.
The formula is right for the magnitude of the electrical dipole. Normally it is
p=Qd where the d-vector goes from the negative to the positive charge and denotes the distance between them...
marlon
