Totally bounded subset in a metric space
A subset A of a metric space M is totally bounded if, for every ε > 0, there exists a finite ε-dense subset of A. The proof requires demonstrating that the finite ε-dense subset leads to a covering of A with sets of diameter less than or equal to ε. The argument must clarify that the balls B(x_j; ε) indeed cover all of A and address the technical detail that the diameter of B(x_j; ε) is not necessarily ε. Proper quantification and explicit coverage of A are essential for a complete proof.
  • Understanding of metric spaces and their properties
  • Familiarity with the concept of ε-dense subsets
  • Knowledge of open balls and their diameters in metric spaces
  • Proficiency in mathematical proof techniques and quantifiers
  • Study the properties of totally bounded sets in metric spaces
  • Learn about the relationship between compactness and total boundedness
  • Explore examples of ε-dense subsets in various metric spaces
  • Review techniques for constructing coverings in metric spaces
Mathematics students, particularly those studying real analysis or topology, as well as educators seeking to clarify concepts related to metric spaces and total boundedness.
tarheelborn
Suppose [tex]M[/tex] is a metric space and [tex]A \subseteq M[/tex]. Then [tex]A[/tex] is totally bounded if and only if, for every [tex]\epsilon >0[/tex], there is a finite [tex]\epsilon[/tex]-dense subset of [tex]A[/tex].
I have already done the [tex]\Rightarrow[/tex] but need to verify the other half:
[tex](\Leftarrow )[/tex]: Now suppose that for [tex]\epsilon > 0[/tex], [tex]A[/tex] has a finite [tex]\epsilon[/tex]-dense subset. I must prove that [tex]A[/tex] is totally bounded. Since there is an [tex]\epsilon[/tex]-dense set in [tex]A[/tex], say [tex]\{ x_1, x_2, \cdots, x_n \}[/tex] is [tex]\epsilon[/tex]-dense in [tex]A[/tex], then [tex]B[x_i; \epsilon], \cdots, B[x_n; \epsilon][/tex] form a covering of [tex]A[/tex] by sets of diameter [tex]< \epsilon[/tex]. Hence [tex]A[/tex] is totally bounded.
Does this work?
This is an essentially correct argument, but for one small technical problem and a few stylistic issues.
The small technical problem is that the diameter of [tex]B(x_j; \epsilon)[/tex] is not necessarily [tex]\epsilon[/tex]; what is it? (Correcting this doesn't change the gist of the argument, but you do need to make adjustments.)
As for the stylistic issues -- Because you're being asked to prove something this simple, it might not hurt to give an explicit argument that the balls [tex]\{B(x_j; \epsilon)\}[/tex] cover all of [tex]A[/tex] -- that is, given any [tex]x\in A[/tex], why does [tex]x[/tex] lie in one of the balls [tex]B(x_j; \epsilon)[/tex]?
Also, you could be more careful about the quantifiers -- it should run something like: Fix [tex]\epsilon > 0[/tex]; we will exhibit a covering of [tex]A[/tex] by finitely many sets of diameter [tex]\leq \epsilon[/tex]. We know that there exists a finite something-dense set in [tex]A[/tex], so ... (continue from here). The important point here is that you need to show the covering exists no matter the choice of [tex]\epsilon[/tex], which isn't clear from what you wrote above.
I see. Thank you.
  • · Replies 16 ·
  • · Replies 25 ·
