Calculating the Maximum Radius of the Observable Universe
  • Thread starter Thread starter kimikims
    Radius Universe
The discussion revolves around calculating the maximum radius of the observable universe based on the time since the big bang and the speed of light. The problem is situated within the context of cosmology and involves understanding the implications of distance, time, and the speed of light.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the relationship between speed, time, and distance, questioning how to properly handle units in the calculation. There is uncertainty about whether simply multiplying the given values will yield a meaningful result.
The discussion is active, with participants providing insights about unit conversion and the importance of using consistent units. Some suggest that the maximum radius can be derived from the speed of light and the age of the universe, while others express confusion about the calculations involved.
There is mention of varying estimates for the age of the universe, indicating that assumptions about this value may influence the calculations. Participants also highlight the need to convert between different time units to ensure the calculations are valid.
kimikims
It is believed that the universe began with a big bang about 19 billion years ago. Neglecting the expansion of the universe, we can reason that the most distant objects obersrvable are no further than the distant light could have traveled in 1.9 x 10^10 yr.
If the speed of light is 2.99792 x 10^8 m/s, what is the maximum possible radius of the observable universe? Answer in units of m.
Do I just need to multiply these two numbers??
If you just multiply those two numbers will your units work out?
I'm not really sure... does anyone know how to do this problem?
You know how to do the problem. Speed times time is distance but you aren't just multiplying numbers. If you simply multiply the speed and time as given your answer will be in units of meter-years per second. While technically correct it isn't particularly meaningful. Faust was properly suggesting that you use like units in your calculation so that you end up with simply meters or kilometers.
I realize the units won't work if i just mulitply them together, but I'm not sure how to find the maximum possible radius of this question
That would give you the largest possible radius because nothing can travel faster than the speed of light - those photons that left early in the formation of the Universe will be further out than any matter.
1 year = 365 1/4 days
1 day = 24 x 60 x 60 = 86400 seconds
1 year = 31557600 seconds.
Use this to convert m/s to m/year
you may want to chose a second more conservative age for the universe to go along with the 19 billion figure because it is still a debate. the oldest I have heard is 15 billion.
you need to convert the seconds into years or the years into seconds.
  • · Replies 23 ·
  • · Replies 47 ·
