New Reply
Axial loading and the change of wall thickness in a cylinder
Share Thread Thread Tools
Nov8-10, 08:26 AM   #1
I'm having trouble with understanding how to calculate a wall thickness change in a hollow cylinder unde axial loading. The length, outside diameter and initial wall thickness are given as well as the size of the load, Young's modulus and Poisson's ratio.
I guess this isn't really a hard question but I just can't get my head around it... I computed the shortening of the pipe as well as the change in diameter, but I don't understand how you should go about working out the change in wall thickness, as I guess you need to think about the solid cylinder that's "missing" from inside the hollow one but do I just calculate the amount that the solid one would extend and then subtract it from how much the hollow one has extended? Sounds wrong...
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Lab sets a new record for creating heralded photons
>> Breakthrough calls time on bootleg booze
New Reply
Tags
axial load, hollow cylinder, wall thickness
Thread Tools
Similar Threads for: Axial loading and the change of wall thickness in a cylinder
Thread Forum Replies
Axial Loading Deformation Engineering, Comp Sci, & Technology Homework 1
Axial Loading of a Drive Shaft Mechanical Engineering 2
Question on deformations of members under axial loading Engineering, Comp Sci, & Technology Homework 1
Beam (composed of two materials) Axial Loading Engineering, Comp Sci, & Technology Homework 8
Stress, Strain - Axial loading (axial forces) Mechanical Engineering 11
