Calculating Vector Surface Integrals in Spherical Coordinates
The problem involves calculating vector surface integrals in spherical coordinates, specifically for a unit radial vector and an exponential function over defined surfaces: the upper hemisphere of a sphere and an octant of a unit sphere. The original poster expresses difficulty in setting up the integral correctly despite knowing the expected answer.
  • Mixed
  • Participants discuss the setup of the integral, questioning the use of coordinates and the proper area element for integration. Some suggest simplifying the integral by treating the exponential function as a constant, while others emphasize the need for proper parameterization and the calculation of the surface area element.
There is ongoing exploration of different approaches to the problem, with participants offering insights into the correct parameterization and integration methods. Some guidance has been provided regarding the use of spherical coordinates and the necessity of calculating the dS vector correctly.
The original poster initially attempted to use cylindrical coordinates, which led to confusion. There is a recognition of the need to clarify the parameterization of the surface and the integration bounds.
musicmar
Let er be the unit radial vector and r=sqrt(x2+y2+z2). Calculate the integral of F=e-rer over:
a. The upper-hemisphere of x2+y2+z2=9, outward pointing normal
b. The octant x,y,z>=0 of the unit sphere centered at the origin
S=<rcos(theta),rsin(theta),sqrt(9-r2)>
int(int(F dot dS))=int(int(F dot erdS))
=int(int(e-r<cos(theta),sin(theta),r> dot <rcos(theta),rsin(theta),sqrt(9-r2)>dr dtheta
The bounds of r are 0 to 3 and theta: 0 to 2pi.
I know the answer from the back of the book (18pi*(e^-3)), but I'm not getting this. Once I have the integral set up correctly, I don't have a problem evaluating it. I apologize for the annoying notation.
hi musicmar! :smile:
(have a theta: θ and a phi: φ and a pi: π and an integral: ∫ :wink:)
erm :redface:why are you using coordinates? :confused:
F.dS = e-r er.er = e-r
just integrate e-r over the area! :wink:
F.dS = e-r er.er = e-r …
If you are saying to do
∫e-rdrdθ, 0<=r<=3, 0<=θ<=2π , that doesn't work. You are trying to integrate F, which is e-r times the unit radial vector. Unless I am misinterpreting your suggestion, I don't think it accounts for the radial vector.
hmm …
i] e-r is a constant, so you can just multiply it by the area, can't you? :smile:
ii] anyway, the area element is rdrdθ, not drdθ :wink:
tiny-tim said:
hmm …
No, the surface area element with cylindrical parameterization is
[tex]dS = \frac {3r}{\sqrt{9-r^2}}\ drd\theta[/tex]
which will give his answer.
Hi LCKurtz! :smile:
But the surface is a hemisphere, so I was using spherical coordinates …
why would one use cylindrical?
tiny-tim said:
Hi LCKurtz! :smile:
Normally, one wouldn't. But that is how the OP set it up in his question so that's the dS he needs to fix his calculations.
Actually, on looking more closely at what the OP did, there is a more basic mistake. To calculate the dS vector he needs to cross the partials of the parameterization of the surface, not just use the parameterization of the surface itself in his setup.
Instead of R = <rcos(theta),rsin(theta),sqrt(9-r2) in his integral he needs to cross Rr and r_theta.
Hi. Thanks for helping. I just went to my professor's office hours and now know how to do this problem. It should be done in spherical coordinates (I don't know why I tried to do it in cylindrical). I'm pretty sure I don't need cross partials. Because r=rho in this case, e-r is simply e-rho. Using spherical coordinates, everything should work out more or less nicely.
  • · Replies 21 ·
