Adiabatic Curvature - Deduce the Local Adiabatic Curvature K
  • Context: Graduate
  • Thread starter Thread starter lyylynn
    Adiabatic Curvature
The local adiabatic curvature K in the context of the Laughlin model of the Quantum Hall Effect is derived from the Berry phase formula. Specifically, K is defined as K = -2 Im < d(psi) phi| d(theta) phi>, where d denotes the partial differential operator. This expression quantifies the geometric phase acquired by a quantum system when traversing a closed loop in parameter space, applicable to any non-degenerate ground state of the Hamiltonian H(psi, theta).
  • Understanding of the Quantum Hall Effect and its mathematical framework.
  • Familiarity with the concept of Berry phase in quantum mechanics.
  • Knowledge of Hamiltonian mechanics, particularly non-degenerate ground states.
  • Proficiency in differential operators and their application in quantum states.
  • Study the derivation and implications of the Berry phase in quantum systems.
  • Explore the Laughlin model in detail, focusing on its applications in condensed matter physics.
  • Investigate the mathematical properties of adiabatic curvature in quantum mechanics.
  • Learn about the implications of non-degenerate ground states in quantum Hamiltonians.
Physicists, particularly those specializing in quantum mechanics and condensed matter physics, as well as researchers interested in the geometric aspects of quantum states and their applications in the Quantum Hall Effect.
lyylynn
Hi,
I am working on the Laughlin model of Quantum Hall Effect, which relates to the concept ' adiabatic curvature'. The paper didn't include much details, and I knew little about berry phase. Could some one please give me some idea that how is the local adiabatic curvature deduced? ( the expression of K below)
Here is the problem: consider a quantum Hamiltonian H(psi, theta). Suppose the Hamiltonian has a non-degenerate ground state at energy zero. Ground state is e^ia|phi(psi,theta)>, a is the initial phase that is free to choose. The local adiabatic curvature K of the bundle of ground states in the parameter space is defined as the limit of the Berry phase mismatch divided by the loop area, turns out to be
K = 2 I am < d(psi) phi| d(theta) phi> (here d indicates partial differential operator)
Thanks a lot.:)
</code>The expression for the local adiabatic curvature K is derived from the Berry phase formula, which is a measure of the geometric phase acquired by a quantum system when cycled through a closed loop in its parameter space. The Berry phase formula is given by B = ∫A F , where A is the area enclosed by the loop and F is the Berry curvature, which is given by F = -2 Im < d(psi) phi| d(theta) phi>. Therefore, the local adiabatic curvature K can be expressed as K = B/A = -2 Im < d(psi) phi| d(theta) phi>. This expression is valid for any non-degenerate ground state of the Hamiltonian H.
  • · Replies 22 ·
  • · Replies 16 ·
