Calculate pH & Concentration of Acids & Bases in Solution
The discussion revolves around calculating the pH and concentrations of acids and bases in a titration scenario involving ethanoic acid and sodium hydroxide. It includes theoretical considerations, mathematical reasoning, and conceptual clarifications related to buffer solutions.
  • Homework-related
  • One participant suggests calculating the moles of ethanoic acid by multiplying concentration and volume, and emphasizes the importance of determining when half of the acid is titrated.
  • Another participant introduces the Henderson-Hasselbalch equation to relate pH to the concentrations of the acid and its conjugate base, indicating that the solution behaves as a buffer.
  • A participant expresses confusion about the concentration values needed for part a and questions the volume of acid used in the titration.
  • There is clarification that ethanoate ions refer specifically to CH3COO-, and that sodium ethanoate is a salt that dissociates into the ethanoate anion.
Participants generally agree on the definitions of the chemical species involved, but there is uncertainty regarding the calculations for concentrations and the specific values needed for the problem. The discussion remains unresolved regarding the exact approach to solving the problem.
Participants have not reached a consensus on the method for calculating the concentrations and pH, and there are unresolved questions about the volume and concentration values required for the calculations.
This discussion may be useful for students or individuals interested in titration calculations, buffer solutions, and the application of the Henderson-Hasselbalch equation in chemistry.
Jack16
Could You Help Me Out With This Question Please:
25.0 cm3 of a solution of 0.1M ethanoic acid is titrated with 0.1M sodium hydroxide.When sufficient alkali has been added to neutralise half of the acid,calculate
a)the concentration of ethanoic acid and ethanoate ions
b)the pH of the solution (Ka=1.7x10^-5 mol dm^-3)
Thanks Very Much!...
Chemistry news on Phys.org
Hello my friend,
First find C1*V1 by multiplying each other to learn the mole number. The same must be supplied in order to achieve neutral state. Where can you determine that half of acid is titrated? Mole numbers, of course.
Then write the equation, to see how many moles of ethanoate ions along with hydrogen ions are produced. Use the equilibrium constant, with omitting some values not needed really. If you can find the unknown value, you've already found the hydrogen concentration, and thus, pH value.
You'd better to solve this question by yourself, so I decided not to give the whole answer. But I'm here for your possible questions about it, with other members.
Remember the salt formed can hydrolise.This is a buffer solution(i.e. on further adition of acid or base,it will resist change in PH).
SO use
Henderson-Hasselbalch equation:
[tex]pH=pK_a+log\frac{[A^-]}{[HA]}[/tex]
Hi guys,
I think that for part b there's no problem. I'm just having a hard time working out the values for concentration for part a. Would ethanoate ions mean CH3COO- or CH3COONa?The volume of acid is surely 12.5cm3?How about the rest of the concentrations and volumes, where would they come from?
Hello, ethanoate ions are [tex]CH_3COO^-[/tex] only. If you add a sodium cation at the end of it, you'll get sodium ethanoate, which is essentially the same product, since sodium ethanoate also ionizes to ethanoate anion.
10K
