Register to reply
Speed of Sound Lab (using slope to find speed of sound)
by goman519
Tags: slope, sound, speed
Share this thread:
goman519
#1
Nov10-10, 12:15 AM
P: 2
If you had data from a lot of different frequencies, how could you use a slope to find the speed of sound? Explain in detail.
Given/Known: So basically we did a lab where we used 3 different tuning forks and hit them over a tube filled with water. We recorded where we heard each node and calculated what half lambda and lamda were in order to find the speed of sound.
2. Relevant equations
Speed of Sound = frequency * wavelength (lambda)
or
Speed of Sound = 331 + 0.61(T)
T = temperature in celsius (which was 20.2 in our class room)
3. The attempt at a solution
Tried taking the slope of my 3 frequencies (523.2, 1024, 2048 (Hz)) and 3 wavelengths (634.67, 316.00, 152.00 (mm) respectively) in excel. First converted the wavelengths to meters. The slope I got was -2.91. Couldn't figure out any correlation and frankly don't think that's the way to approach the problem.
Solution or any kind of tip very much appreciated. Thanks guys.
Phys.Org News Partner Science news on Phys.org
FIXD tells car drivers via smartphone what is wrong
Team pioneers strategy for creating new materials
Team defines new biodiversity metric
fzero
#2
Nov10-10, 02:16 AM
Sci Advisor
HW Helper
PF Gold
P: 2,602
The expected relationship between the frequency and wavelength is one of inverse proportion
[tex] \lambda = \frac{v_s}{f}. [/tex]
The speed of sound [tex]v_s[/tex] could be computed from the slope of a fit to the data where you plot [tex]\lambda[/tex] vs. [tex]1/f[/tex], instead of [tex]\lambda[/tex] vs. [tex]f[/tex].
goman519
#3
Nov10-10, 03:48 PM
P: 2
Quote Quote by fzero View Post
Ok cool. I see how that works and when I got the slope I had a very small percent error so thanks.
Only thing is, my teacher emailed me about the question and told me to differentiate the equation for velocity of sound. To look at dy/dx. I'm not really sure how to do that correctly.
Wouldn't differentiating V=lambda F give you 1 = lambda + F ? Any idea what she wants me to do?
Register to reply
Related Discussions
Wavelength of sound waves and speed of sound in air column Introductory Physics Homework 1
Sound wave : find the speed Introductory Physics Homework 5
Velocity of Sound, speed of rock and return of sound Introductory Physics Homework 1
Find distance using speed of sound Introductory Physics Homework 12
Speed of sound and sound detection lag between ears Introductory Physics Homework 5
