Is the Boltzmann Equation in GR Truly Coordinate Independent?
The discussion revolves around the coordinate independence of the Boltzmann equation within the framework of General Relativity (GR). Participants explore the implications of Christoffel symbols and derivatives in the context of the collisionless Boltzmann equation, examining whether certain terms can be considered covariant or not.
  • One participant questions how the term involving Christoffel symbols in the Boltzmann equation can be coordinate independent, given that Christoffel symbols do not transform like tensors.
  • Another participant points out that the derivative in the equation is not a covariant derivative, which complicates the assertion of covariance for the second term.
  • Some participants assert that the first term of the equation is manifestly covariant because it involves a scalar function, while others challenge this view by emphasizing the nature of the derivatives used.
  • There is a discussion about the definition of tensors, with some participants noting that Wald describes the Christoffel symbol as a tensor but acknowledges its non-standard transformation properties.
  • A participant highlights that the second term arises from the geodesic condition, suggesting a connection to the underlying geometry.
  • Another participant discusses the transformation rules for the momenta and how they relate to the covariance of the equation, indicating that second derivatives may play a role in the transformation process.
  • One participant expresses uncertainty about the covariance of the second term and seeks further clarification and references to understand the transformation rules better.
Participants express differing views on the covariance of the terms in the Boltzmann equation, with no consensus reached on whether the second term is indeed covariant. The discussion remains unresolved regarding the implications of the Christoffel symbols and the nature of the derivatives involved.
Participants note that the discussion involves complex mathematical transformations and the distinction between covariant and partial derivatives, which may not be fully resolved within the current exchanges.
DrFaustus
Hi everyone,
have a question about covariant, coordinate independent quantities in GR.
Reading Kolb and Turner's book The Early Universe one can find the Boltzmann equation in a GR setting. Now, one of the terms in that equation is
[tex]- \Gamma_{\alpha \beta}^\gamma p^\alpha p^\beta \frac{\partial f}{\partial p^\gamma}[/tex]
where [tex]\Gamma[/tex] is the Christoffel symbol, [tex]f = f(x^\mu, p_\mu)[/tex] is the particle distribution function, which is a scalar and depends on the coordinates [tex]x^\mu[/tex] and the momenta [tex]p_\mu[/tex].
My question now is simply how to see that this is a coordinate independent quantity? The Christoffel symbols do not transform like tensors, but the above formula really should be a scalar quantity, like the index notation suggests. So my guess is that the partial derivative with respect to the momenta must transform in a way so to make the above a scalar. Is this correct? Can you explain in some detail? Or give me some references to check it out?
Thanks!
Even ignoring the fact that the Christoffel symbol isn't a tensor, there's also the issue that the derivative is not a covariant derivative. It might be easier to figure this out if you give us the whole equation.
It's the collisionless Boltzmann equation:
[tex]p^\mu \frac{\partial f}{\partial x^\mu} - \Gamma_{\alpha \beta}^\gamma p^\alpha p^\beta \frac{\partial f}{\partial p^\gamma} = 0[/tex]
The first term is manifestly covariant, and so should be the second one.
As for the Christoffel symbol, Wald states it is a tensor. The reason why it does not transform like one might suspect is that it is associated to a non-covariant derivative, which depends on the coordinates. So when you change coordinates you are forced to change the Christoffel tensor as well. See page 34 of his book, after equation 3.1.15. But I know there's confusion about it, and I myself am not totally clear on the situation.
Any insight is helpful...
No, the first term is not manifestly covariant, because it's a partial derivative, not a covariant derivative.
Wald calls it a tensor, but says that it doesn't transform as a tensor. Most people only define a thing to be a tensor if it transforms as a tensor.
The first term is manifestly covariant because f is a scalar and for scalar quantities the covariant derivative coincides with the usual partial derivative...
I don't quote see the covariance of the second terrm right now, and I probably won't get any chance to think about this tomorrow. I can see that the second term comes from the geodesic condition.
Some people make a distinction between a tensor and a tensor field.
Ah, sorry -- you're right and I was wrong.
This is an equation on the tangent bundle. Notice that you have derivation with respect to the coordinates of the tangent vector [tex]p^\alpha[/tex] and not with respect to [tex]x^\alpha[/tex]. The transformation rule involves then second derivatives.
george.jones -> Good observation, the second term comes from the geodesic condition indeed.
arkajad -> That's precisely what I'd like to understand better. I know it's a derivative wrt [tex]p^\alpha[/tex], which is why I think the full equation should be covariant. Could you give me some more details or a reference where to look up this stuff? What is the transformation rule you mention?
I can' find it right away in a book, but the idea is simple. You have
[tex]p^\alpha=\frac{\partial x^\alpha}{\partial x^{\alpha'}}p^{\alpha'}[/tex]
therefore
[tex]\frac{\partial f(x,p)}{\partial x^{\alpha'}}<br /> =\frac{\partial f}{\partial x^\alpha}\frac{\partial x^\alpha}{\partial<br /> x^{\alpha'}}<br /> +\frac{\partial f}{\partial p^\alpha}\frac{\partial<br /> p^\alpha}{\partial x^{\alpha'}}[/tex]
Now, the last term gives you
[tex]\frac{\partial p^\alpha}{\partial x^{\alpha'}}=\frac{\partial^2 x^\alpha}{\partial x^{\alpha'}\partial x^{\beta'}}\,p^{\beta'}[/tex]
This should cancel out with what comes from the second term - though one will need to play with derivatives of the inverse matrix - a little calculational trick is needed (if you want, I can explain it).
  • · Replies 17 ·
  • · Replies 19 ·
