FInding Points of Tangent Line w/ Vectors
The discussion focuses on finding points on the ellipsoid defined by the equation 4x² + 2y² + z² = 19 where the tangent plane is parallel to the plane described by 2y - 8x + z = 0. The normal vector to the tangent plane is identified as <8x, 4y, 2z>, while the normal vector to the given plane is <-8, 2, 1>. Participants conclude that to find the required points, one must set the normal vectors in proportional ratios and substitute these into the original ellipsoid equation.
  • Understanding of ellipsoids and their equations
  • Knowledge of vector mathematics, specifically normal vectors
  • Familiarity with the concept of tangent planes
  • Ability to manipulate algebraic equations
  • Study the properties of ellipsoids and their tangent planes
  • Learn about vector ratios and their applications in geometry
  • Explore methods for solving systems of equations involving multiple variables
  • Investigate the use of Lagrange multipliers for constrained optimization problems
Students studying multivariable calculus, mathematicians interested in geometric properties, and educators teaching vector calculus concepts.
Loppyfoot
Consider the ellipsoid 4x^2+2y^2+z^2 = 19. Find all the points where the tangent plane to this ellipsoid is parallel to the plane 2y−8x+z = 0.
So I found the normal vector to the tangent, <8x,4y,2z>.
I also found the normal vector to the plane, <-8,2,1>
So what step do I do next? I'm Confused on where to go after this.
Hi Loppyfoot! :smile:
(try using the X2 icon just above the Reply box :wink:)
But you're there!
Just make the two parallel (ie in the same ratios), to find an equation for x/z and y/z, and then put them into the original ellipse equation to find the points on the actual ellipse. :smile:
