Tangent Plane Perpendicular to Vector <1,0,2> on x^2+y^2-z^2=-1 Surface
  • Thread starter Thread starter Loppyfoot
    Plane Tangent
The problem involves finding points on the surface defined by the equation x^2+y^2-z^2=-1 where the tangent plane is perpendicular to the vector <1,0,2>. Participants express confusion regarding the relationship between the gradient of the surface and the given vector.
  • Participants discuss the gradient of the surface and its relation to the tangent plane. There is an exploration of the dot product between the gradient and the vector <1,0,2>, with some questioning how to proceed after establishing this relationship.
Some participants have clarified their understanding of the relationship between the gradient and the tangent plane. There are ongoing discussions about how to express variables in terms of each other and whether to set certain variables to zero to simplify the problem.
Participants are navigating the constraints of the problem, including the need to satisfy the surface equation while exploring the conditions for the tangent plane's orientation. There is mention of potential confusion regarding the roles of the variables involved.
Loppyfoot
Find all the points on the surface x^2+y^2-z^2=-1 where the tangent plane is perpendicular to the vector <1,0,2>.
I'm confused!
So, the gradient would be: <2x,2y,-2z>, but what do I do with the gradient vector to find these points?
thanks in advance!
I'm confused!
At a given point on the surface, the gradient is perpendicular to the tangent plane at that surface. Does that give you any ideas?
Yes I understand that point. I'm confused on how to computationally solve this problem.
Any thoughts?
What does that tell you about the relationship between (2x, 2y, -2z) and (1,0,2)
So <2x,2y,-2z> dotted with <1,0,2> = 0
Ok, So if I do the dot product, I get:
2x-4z = 0 . So , x=2z. If I plug that into the original equation, I get:
4z^2 + y^2 -z^2 = -1 . Should I solve for y in terms of z?
No, you have that completely backwards! [itex]\nabla f[/itex]= < 2x, 2y, -2z> is itself normal to the tangent plane. You want <2x, 2y, -2z> to be parallel to < 1, 0, 2>. You are solving for a vector perpendicular to <1, 0, 2>.
Two vectors are parallel if and only if one is a multiple of the other: <2x, 2y, -2z>= <a, 0, 2a> for some number a.
Ok, Now I understand. So I should solve for k first:
2x= k ; 2y=0 ; -2z=2k .
So x = k/2 and z=-k. If I substitute those back into the original equation, I get
k^2/4+ y^2-k^2 = -1. But I have two variables. Should I have set the y=0 so I can solve for k?
any ideas?
You're not solving for k; you're solving for x, y, and z.
Don't forget y = 0.
Yes.
