How Do You Calculate the Pulling Force on a Crate for Zero Net Work?
  • Thread starter Thread starter rocky811
    Work Work problem
The discussion focuses on calculating the pulling force (P) required to ensure zero net work on a 116-kg crate being pulled at an angle of 35.2° above the horizontal, with a coefficient of kinetic friction of 0.212. The key conclusion is that the horizontal component of the pulling force must equal the kinetic friction force to achieve this condition. The relationship W = FdCos(θ) and the formula for kinetic friction (fs = uk * F) are essential in solving the problem, emphasizing that the work done by the pulling force and the work done against friction must cancel each other out.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of work and energy
  • Knowledge of kinetic friction and its calculation
  • Basic trigonometry for resolving forces into components
  • Study the principles of static and kinetic friction in physics
  • Learn how to resolve forces into horizontal and vertical components
  • Explore the concept of net work and its implications in mechanics
  • Practice problems involving forces at angles and frictional forces
Students studying physics, particularly those focusing on mechanics, as well as educators and anyone interested in understanding the dynamics of forces acting on objects in motion.
rocky811
Hello! I need a little help here. I have been trying to figure out this problem, but I just can't and I don't know where I am going wrong.
A 116 -kg crate is being pulled across a horizontal floor by a force P that makes an angle of 35.2 ° above the horizontal. The coefficient of kinetic friction is 0.212 . What should be the magnitude of P, so that the net work done by it and the kinetic frictional force is zero?
now I know what W=FdCos(theta) and that fs=uk*F...but I just don't know where to go from there and I don't know what the end of the question means..."so that hte net work done by it and the kinetic frictional force is zero?"...does that mean I just set the net work and frictional force equal and solve for the force?
Any moving object on a surface with friction will have kinetic friction.
Ah I am starting to see now. The question intends to ask "what should P be if the work done by you and the work done by kinetic friction cancel each other out?" So yeah you're right - almost. You can't set work equal to force because they are not of the same unit. Set your horizontal component of P equal to the kinetic friction experienced because if both forces cancel each other out, no work can be done in moving the box even if it's moving at a constant speed.
Thanks! That's exactly what someone said when I asked them about it today and it worked.
  • · Replies 28 ·
