Sergei Winitzki's GR Book: Examining Errors in Conformal Transformations
  • Context: Graduate
  • Thread starter Thread starter bcrowell
Sergei Winitzki's General Relativity (GR) book presents a treatment of conformal transformations that raises questions regarding the correctness of certain expressions. Specifically, on page 85, the expression for \tilde{r}(i^o) should utilize e^{2\lambda} instead of e^{\lambda}. Additionally, the condition for the limit involving f'(s) going like s^{-n} should be n≥1 rather than n≥2, as this impacts the analysis of pointlike and non-pointlike structures in the context of Penrose diagrams. The discussion emphasizes the need for n=2 to maintain the analytic and positive-definite nature of f'.
  • Understanding of General Relativity concepts, particularly conformal transformations.
  • Familiarity with Penrose diagrams and their significance in GR.
  • Knowledge of limits and asymptotic behavior in mathematical analysis.
  • Proficiency in handling mathematical expressions involving exponential functions and derivatives.
  • Study the implications of conformal transformations in General Relativity.
  • Research the role of Penrose diagrams in representing spacetime structures.
  • Learn about the behavior of functions under limits, focusing on asymptotic analysis.
  • Examine the properties of analytic functions and their relevance in GR.
Researchers, physicists, and students in the field of General Relativity, particularly those interested in conformal transformations and their mathematical underpinnings.
bcrowell
Staff Emeritus
Insights Author
Sergei Winitzki has a very nice copylefted GR book: http://sites.google.com/site/winitzki/index/topics-in-general-relativity (direct PDF link: http://sites.google.com/site/winitzki/index/topics-in-general-relativity/GR_course.pdf?attredirects=0&d=1 ) I'm puzzling over his treatment of conformal transformations.
On p. 85, near the bottom left corner of the page, he has
[tex]\tilde{r}(i^o)=\lim_{r\rightarrow\infty}e^\lambda r^2=\lim_{v\rightarrow -\infty, u\rightarrow\infty}f'(u)f'(v)\frac{(u-v)^2}{4}[/tex].
Comparing with the expressions near the top of the column, it seems to me that the [itex]e^\lambda[/itex] should clearly be [itex]e^{2\lambda}[/itex]. I emailed him about this, hoping that I wasn't just making some dumb mistake.
After this, there is another thing that seems wrong to me, but considering that my understanding of GR is far inferior to his, I'm a little hesitant to shoot off another email. He says suppose that f'(s) goes like s-n for large s; then the limit in the third expression above should approach zero if [itex]n\ge 2[/itex]. But shouldn't the condition be [itex]n\ge 1[/itex]??
If I'm right about the second error, then it's a more substantial hole in his analysis. Basically you want io to be pointlike (a 2-sphere of radius 0) and points on scri+ to be non-pointlike (each such point represents a 2-sphere of finite radius). The best motivation I know of for wanting these to be this way is that it allows you to make a tiling of Penrose diagrams to cover the static Einstein universe. (Is there some more fundamental reason?) So the condition on io requires [itex]n\ge 1[/itex], and the condition on scri+ forces [itex]n\le 2[/itex]. But then this leaves a whole range of possible exponents between 1 and 2 (contrary to Winitzki's analysis, which fixes the exponent uniquely at 2). Does this seem right?
One would then need some other reason to pick n=2. I think that if you want f' to be analytic and positive-definite, then that does rule out n=1, or any other value besides n=2. Does this make sense?
Surely it should be [tex]e^{2\lambda}.[/tex] As for n, for [tex]n>1[/tex] the limit is zero, for [tex]n<1[/tex] the limit is infinite. For n=1 the limit will probably depend on the direction (speed) you approach the infinity.
Suppose [tex]\left( u , v \right) = \left( e^t , t \right)[/tex] and [tex]f'\left(s\right) = s^{-n}[/tex]. Then,
[tex] u^{-n} v^{-n} \frac{\left( u - v \right)^2}{4} = e^{-nt} t^{-n} \frac{\left( e^t - t \right)^2}{4}.[/tex]
Small correction: In Winitzki's text he wants:
"... corresponding to [tex]r\rightarrow\infty\quad (u\rightarrow\infty,\, v\rightarrow -\infty).[/tex]"
arkajad said:
In Winitzki's notes he writes:
Oops. I didn't see the minus sign in [itex]-\infty[/itex] at the bottom of the limit above. And I just got my eyes checked and new glasses a couple of months ago.
Suppose [tex]\left( u , v \right) = \left( e^t , -t \right)[/tex] and [tex]f'\left(s\right) = s^{-n}[/tex]. Then,
[tex] u^{-n} v^{-n} \frac{\left( u - v \right)^2}{4} = \left(-1\right)^{-n} e^{-nt} t^{-n} \frac{\left( e^t + t \right)^2}{4}.[/tex]
[edit]The (-1)^(-n) is not nice, but I think that this suggests that n >= 2 is needed[/edit]
Winitzki has
[tex]e^{2\lambda}=f'(u)f'(v)[/tex]
Therefore the product [tex]f'(u)f'(v)[/tex] should always be positive. Anyway the result goes to zero for any [tex]n>1[/tex]. Since Wintzki probably assumes n to be an integer (though I do not know why?), it starts with n=2 or higher.
I have them self-checked and have about 20 pairs of different glasses, each for about $3.
Thanks very much, arkajad and George Jones, for your replies!
When Winitzki says f' "tends to zero as s-n," he could mean (a) that f' has limiting behavior that is that same as that of s-n, up to a constant factor of proportionality, with a relative error that approaches zero. On the other hand, he could mean (b) that f' is bounded above by something of the form k|s-n|, and that n is the largest real number such that you can make a bound like this. In case b, we could have possibilities like f'(s)=1/|s|, so that the sign is not an issue. We would probably like f' to be C, but then we can still make up possibilities like [itex]f'(s)=1/\sqrt{1+s^2}[/itex], which is not analytic.
There is also the question of whether he intends the limit to be independent of the direction from which you approach io. In the following paragraph, he talks about approaching a particular point on [itex]\mathscr{I}+[/itex] along a particular light ray. If you approach io along a spacelike curve, I think only [itex]n\ge 1[/itex] is required. George's [itex] \left( u , v \right) = \left( e^t , -t \right)[/itex] is timelike.
Trying to put all this together, here's what I get. He has two physical requirements, one on io and one on [itex]\mathscr{I}+[/itex]. The latter seems to be all that is really required. If you want every point on [itex]\mathscr{I}+[/itex] to represent a 2-sphere with a nonzero, finite radius, then this should certainly be true in the case where you approach that point along a lightlike geodesic, and therefore we need n=2 exactly. It seems like we would also like the same finite-r limit if we approach a point on [itex]\mathscr{I}+[/itex] along any other curve, and I don't know if this holds or not. Once we've fixed n=2, it also follows that r=0 at io, regardless of the curve along which the limit is taken.
-Ben
  • · Replies 0 ·
  • · Replies 22 ·
  • · Replies 56 ·
12K
  • · Replies 150 ·
22K
  • · Replies 98 ·
16K
