How Fast Is the Angle of Elevation Changing as the Rocket Ascends?
The discussion focuses on calculating the rate of change of the angle of elevation of a rocket ascending vertically at 6 miles per minute, with an observer positioned 4 miles away from the launch site. When the rocket reaches a height of 3 miles, the angle of elevation is determined to be approximately 36.87 degrees. The final result shows that the angle of elevation changes at a rate of 0.64 degrees per minute. The solution involves using the derivative of the tangent function and applying the chain rule effectively.
  • Understanding of trigonometric functions, specifically tangent and secant.
  • Knowledge of derivatives and their application in related rates problems.
  • Familiarity with the concept of angle of elevation in relation to horizontal distance.
  • Basic calculus skills, including the chain rule and quotient rule.
  • Study the application of related rates in calculus problems.
  • Learn more about the derivative of trigonometric functions, focusing on secant and tangent.
  • Explore practical examples of angle of elevation calculations in physics.
  • Investigate the use of implicit differentiation in related rates scenarios.
Students studying calculus, particularly those focusing on related rates problems, as well as educators looking for examples of real-world applications of trigonometry and derivatives.
MysticDude
A rocket is fired vertically into the air at a rate of 6 mi/min. An observer on the ground is located 4 miles from the launching pad. When the rocket is 3 miles high, how fast is the angle of elevation between the rocket and the observer changing? Be sure to specify units.
Derivative of tanθ = sec²θ
Ok well I know that at that moment that θ is tan-1(3/4) which is 36.870°. Then I went ahead and set up my equation as tanθ = y/x. Taking the derivative of both sides I get:
[tex]\theta'sec^{2}(\theta) = \frac{xy' - yx'}{x^2}[/tex] then I substitute for the values and I get θ'sec²(θ) = 1. Finally, I divide both sides by sec²θ to get my final answer that θ' = .64 degrees per minute.
Thanks for any help guys!
Not sure exactly what your question is. You have the correct answer. You might have come to it easier if you had started with the equation tan(θ) = y/4 instead of y/x. You don't need the quotient rule because x is a constant. This gives you directly that
sec2(θ) θ' = y'/4 = 3/2
Hehe, oopsie. Thanks for the help LCKurtz! :D
