Express one vector as a linear combination of others
The discussion focuses on demonstrating that the set of vectors {(1,2,3), (3,2,1), (5,5,5)} is linearly dependent by expressing one vector as a linear combination of the others. The user systematically set up the equations a(1,2,3) + b(3,2,1) + c(5,5,5) = 0 and derived relationships between the coefficients a, b, and c. Ultimately, they confirmed linear dependence by substituting values and verifying the identity holds true, concluding that the vectors are indeed multiples of each other.
  • Understanding of linear dependence and linear combinations
  • Familiarity with solving systems of linear equations
  • Basic knowledge of vector operations in R³
  • Proficiency in algebraic manipulation of equations
  • Study the concept of linear independence in vector spaces
  • Learn about the rank of a matrix and its relation to linear dependence
  • Explore the method of Gaussian elimination for solving linear systems
  • Investigate applications of linear combinations in computer graphics and data science
Students and educators in linear algebra, mathematicians, and anyone interested in understanding vector spaces and their properties.
Saladsamurai
Show that the set of vectors is linearly dependent (LD) by expressing one vector as a linear combination (LC) of the others:
I would like to do this systematically (without guess and check). So I assumed that if the set is LD, then there exists some values of a,b,c not all zero such that:
hence,
a + 3b +5c = 0
2a + 2b +5c = 0
3a + 1b +5c = 0
Now I should be able to solve for 2 of the parameters (assuming only one of the equations is not independent, else I an solve for 1 ...)) a,b,c in terms of the third which would remain arbitrary.
Eliminating c from the first and second equations, we find that a = b .
Eliminating b, from the second and third equations we find that c = -4a/5 .
Now, if I plug these values back into anyone of the equations, I simply get the identity. What am I missing here? Am I messing something up? Or are they ALL multiples of each other?
Thanks!
I'm confused. Haven't you done what you wanted to? You seem to have found everything in terms of a.
Oh. Maybe I have :redface: So here, a is my arbitrary parameter. Say, I let a = 1, then b = 1 and c = -4/5. Plugging these into the original equation, yields:
(1,2,3) + (3,2,1) - (4,4,4) = 0 which is indeed true.
I'm a little slow tonight. :smile:
