Designing a 64k 8 Bit Word Memory Unit with 4096x4 Chips
  • Thread starter Thread starter mathrocks
    Memory
The design of a 64k 8-bit word memory unit requires a total of 32 memory chips, specifically 4096x4 configuration chips. Each 4096x4 chip provides 4096 addresses and 4 bits per address. To achieve the required 64k addresses, 16 chips are necessary, and since each chip only provides 4 bits, two chips are needed per address to meet the 8-bit requirement. Therefore, the total number of chips needed is 16 multiplied by 2, resulting in 32 chips.
  • Understanding of memory chip configurations (e.g., 4096x4)
  • Knowledge of binary addressing and bit requirements
  • Familiarity with memory unit design principles
  • Basic arithmetic for calculating total chip requirements
  • Research memory chip specifications and configurations
  • Learn about binary addressing in digital systems
  • Explore memory unit design methodologies
  • Investigate the impact of chip density on memory performance
Electronics engineers, computer architects, and students studying digital systems who are involved in memory design and optimization.
mathrocks
Hi, how do you go about figuring out how many memory chips are needed to design a memory unit that contains 64k 8 bit words and each memory chip is 4096x4?
Thanks
Well, each of your 4k x 4 chips provides 4k addresses. You need 64k addresses, so you're going to need 16 of those chips just to get enough addresses. Futhermore, each chip only provides 4 bits per address, and you need 8 bits per address, so you'll need two chips per address. Thus, you'll need 16 * 2 = 32 chips.
- Warren
  • · Replies 25 ·
  • · Replies 35 ·
