Is it a problem if Tresca is larger than Von Mises for yield loci graph?
  • Thread starter Thread starter george88b
    Von mises
The discussion revolves around the relationship between Tresca and von Mises yield criteria in the context of a shaft's stress analysis. Participants explore the implications of finding a larger Tresca value compared to von Mises when plotting yield loci graphs, addressing both theoretical and practical aspects of yield criteria in materials.
  • One participant questions whether it is a problem if the Tresca yield value is larger than the von Mises value, noting their specific calculated values.
  • Another participant suggests that the von Mises threshold should be larger and implies a possible calculation error on the part of the original poster.
  • A participant expresses confidence in their calculations despite being challenged, indicating potential issues with the signs of principal stresses.
  • Some participants clarify that the von Mises yield boundary is typically larger than the Tresca yield boundary, suggesting that a smaller effective stress from von Mises indicates a less conservative approach to yield prediction.
  • Another participant shares their own calculations for a different shaft scenario, providing values for direct and shear stress, as well as principal stresses, to support their discussion.
  • One participant agrees with the assertion that the Tresca theory is overly conservative and that ductile materials behave more closely to the von Mises theory, reinforcing the expected relationship between the two yield envelopes.
  • There is a question about the graphical representation of the yield loci, with one participant seeking confirmation that the von Mises circle is inside the Tresca hexagon, while another participant corrects this understanding, stating that the von Mises yield boundary surrounds the Tresca yield boundary.
Participants express differing views on the relationship between the Tresca and von Mises yield criteria, with some asserting that the von Mises yield boundary should be larger, while others maintain that the observed results are expected. The discussion remains unresolved regarding the specific calculations and interpretations of the yield criteria.
Participants reference specific calculations and stress values, but there are indications of potential misunderstandings regarding the signs of principal stresses and the implications of the yield criteria. The discussion highlights the complexity of determining yield boundaries and the conditions under which different theories apply.
george88b
hello there
i have a shaft..i found the von mises and the tresca..von mises is 360 and tresca is 430. So when i m trying to produce the loci graph the tresca will be bigger than von mises. I search in internet and there is no examples like that. Is there a problem if the tresca is bigger than von mises?
thnx...
Hi george88b, welcome to PF!
The von Mises threshold should be larger, so you probably made a calculation error. If you post your solution, you'll likely get helpful comments.
thnx for reply..i don't think so that i have error with my solutions because i solved them a 1000 times..:) i have a compressive stress 16.55 MPa and shear stress 95.5 MPa. So the principal stresses are.. σ1=87.5 and σ2=-104.1. Right?;p i think may be my wrong is on principal stresses..(signs). Then i have von mises=365.8 and tresca=422
Perhaps you've made the same error 1000 times. If you don't show your work, we can't help you.
CS
Also, I think there may be some misunderstanding. The von Mises yield boundary is larger than the Tresca yield boundary. But this means that the von Mises stress value ([itex]\sqrt{[(\sigma_1-\sigma_2)^2+(\sigma_1-\sigma_3)^2+(\sigma_2-\sigma_3)^2]/2}[/itex]) is smaller than the Tresca stress value ([itex]|\sigma_1-\sigma_3|[/itex]). A smaller effective stress means that the von Mises calculation is less conservative with respect to avoiding yield, which is equivalent to having a larger yield boundary.
I am facing the same problem. The question is: 200mm shaft, Torque= 150KNm, Compressive Load= 520 KN.
Direct stress= -520*10^3/(π*(0.1^2))= -16.55 MPa
Shear Stress=((150*10^3)*0.1)/((π*0.2^4)/32)=95.49 MPa
Principal Stresses:
σ1=0.5(-16.55*10^6)+0.5*sqrt((-16.55*10^6)^2 +4(95.49*10^6)^2)=87*10^6
σ2=0.5(-16.55*10^6)-0.5*sqrt((-16.55*10^6)^2 +4(95.49*10^6)^2)=-104*10^6
to find the tresca i use that formula(i have safety factor 2.2):
|σ1-σ3|=σyield/safety factor and my result is: 421*10^6
to find the von mises:
(σ1^2)+(σ2^2)-(σ1*σ2)=(σyield^2)/Safety factor
and my result is 365*10^6.
the same with me..;p
I agree with the second post by Mapes. Well said. The Tresca (maximum shear stress) theory is an overly conservative theory. Ductile materials behave closer to von Mises theory. Therefore, you know the Tresca failure envelope is enclosed within the von Mises failure envelope. Consequently, we know the Tresca effective tensile stress will always be greater than or equal to the von Mises stress. george88b and mikex24, you are observing the correct, expected result.
And here is a bit of trivia. Even though the maximum shear stress theory often bears the name Tresca, did you know Charles-Augustin de Coulomb invented the theory 95 years before Tresca published his paper?
so at the yield loci graph the von mises will be smaller than the tresca right? i mean that the circle(von mises) will be inside of the hexagon(tresca) if i m right..
No. As stated earlier, the von Mises yield boundary, or yield envelope, surrounds the Tresca yield boundary. When determining the yield boundary, you are setting the von Mises or Tresca effective stress equal to the yield stress, and then asking what combination of principal stresses could give this result. When determining whether a material will yield, you are calculating the effective stress from the principal stresses. Does this make sense?
