Can a neutral pion go to two electron anti electron pairs
  • Context: Graduate
  • Thread starter Thread starter James1991
    Electron Neutral Pion
A neutral pion can decay into two electrons and two positrons primarily through electromagnetic interactions, with a branching ratio of 3.2E-5. This decay is significantly suppressed compared to the two-photon decay mode, approximately by a factor of α², where α represents the fine structure constant. While there exists a negligible weak component mediated by Z bosons, the dominant interaction in this decay process is electromagnetic.
  • Understanding of particle physics, specifically pion decay mechanisms.
  • Knowledge of electromagnetic interactions and the fine structure constant (α).
  • Familiarity with weak force interactions and Z boson mediation.
  • Basic grasp of branching ratios in particle decay processes.
  • Research the implications of the fine structure constant (α) in particle decay.
  • Study the characteristics and decay modes of neutral pions.
  • Explore the role of Z bosons in weak interactions.
  • Investigate the comparison between electromagnetic and weak force decay processes.
Particle physicists, students studying quantum mechanics, and researchers interested in decay processes of mesons.
James1991
Basically can a neutral pion go to two electrons and two positrons and under what interaction would it do this?
I know its defiantly not the strong force, so is it weak or EM? I'm pretty sure its EM but not 100%
Thanks
Thanks
Yes indeed this decay is observed with a branching ratio of 3.2E-5, which is consistent with being suppressed (relative to the two photon decay) by an approximate factor of [itex]\alpha^{2}[/itex], where [itex]\alpha[/itex] is the fine structure constant. Based on this information alone you should be able to deduce that this decay is predominantly electromagnetic. (It turns out that it has an additional but totally negligible weak component which comes from Z mediation instead of photons.)
10K
  • · Replies 0 ·
