Power Series Representation of a Function when a is a polynomial
The discussion revolves around finding a power series representation for the function f(x) = (1+x)/(1-x)² and determining its radius of convergence. The subject area includes power series and convergence criteria.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss various attempts to derive the power series, including expanding the function and differentiating it. Questions arise regarding the correctness of the derived series and the methods used to simplify or manipulate the expressions.
The discussion is active, with participants exploring different methods to arrive at the power series. Some guidance has been offered regarding the need to collect terms and check for patterns in the series. There is acknowledgment of differing results, and participants are encouraged to clarify their approaches.
Participants are working under the constraints of homework rules, which may limit the information they can use or the methods they can apply. There is an emphasis on understanding the derivation process rather than simply obtaining the final answer.
AceK
Power Series Representation of a Function when "r" is a polynomial
Find a power series representation for the function and determine the radius of convergence.
f(x)=[tex]\stackrel{(1+x)}{(1-x)^{2}}[/tex]
a series converges when |x|<1;
[tex]\stackrel{a}{1-r}[/tex]=[tex]\sum[/tex]a(r)[tex]^{n}[/tex]
I got the power series of [tex]\sum[/tex](1+x)(2x-x^2)[tex]^{n}[/tex] by expanding the denominator of the function and getting it into geometric series form; I then converted it to a series using the above equation. The answer given in my book is [tex]\sum(2n+1)x^{n}[/tex], which seems more correct; also, the radius of convergence is much easier to determine with their answer. How do they arrive at this answer?
Your answer isn't a power series. You'd need to multiply everything out and collect terms so that you end up with each term in the series being a number multiplied by a single power of x.
To find the series of the function in the problem, start with the series for 1/(1-x) and note that 1/(1-x)2 is the derivative of 1/(1-x).
I see. So I reworked the problem by differentiating f(x) with the numerator factored out, and the answer I got was (1+x)*[tex]\Sigma(-nx^{n-1}[/tex]which is equal to [tex]\sum(-nx^{n-1}-nx^{n}[/tex], which is still drastically different to the answer given in the book. Is my answer right but reducible, or have I made a mathematical error?
What?
You have to collect terms. Try working out the first four or five terms explicitly and see if you can spot a pattern.
Wow, I've got it now. I was making that way more difficult than it needed to be. Thanks so much for your help, you really elucidated the problem for me.
  • · Replies 22 ·
