Transistor Current Greetings - Variation in AC Signal
  • Thread starter Thread starter amaresh92
    Current Transistor
The discussion focuses on the behavior of a transistor in a common-emitter configuration when subjected to an AC signal. It is established that varying the base current will result in corresponding variations in the collector and emitter currents, which amplify the input signal. The base current remains positive and does not reverse direction, but its magnitude directly influences the collector current. The relationship between base, collector, and emitter currents is defined by the equation: emitter current = base current + collector current.
  • Understanding of common-emitter configuration of BJTs
  • Knowledge of transistor current relationships (base, collector, emitter)
  • Familiarity with AC signal characteristics
  • Basic electronics principles regarding current flow
  • Study the common-emitter configuration of BJTs in detail
  • Learn about transistor biasing techniques for AC signals
  • Explore the relationship between input and output currents in BJTs
  • Investigate the effects of varying AC signal frequencies on transistor performance
Electronics students, circuit designers, and engineers interested in understanding transistor behavior in AC applications.
amaresh92
greetings-
suppose a transistor connected with emitter and collector resistor.
when this transistor is given a AC signal, will the current through the emitter and collector resistor will vary as input AC signal varies? variation in AC signal in the sense the direction of flow of current.
thanks
amaresh92 said:
greetings-
thanks
You are describing the common-emitter configuration of a BJT:
http://en.wikipedia.org/wiki/Common_emitter
And yes, as you vary the base current, that will vary the (amplified) collector & emitter currents. Your base bias does not go negative, however. It varies in positive values to control the collector current.
amaresh92 said:
greetings-
thanks
I might mention finite current always needs to be flowing Into the base. Its "direction" should not change but its value will vary. Min base current - min collector current : Max base current - max collector current
and emitter current = base current + collector current
Sorry if that's too elementary but I'm not exactly sure what your question means.
9K
  • · Replies 19 ·
