Basic question about how spin changes in time
  • Context: Graduate
  • Thread starter Thread starter Turtle492
    Spin Time
The discussion revolves around the time-dependence of quantum spin, particularly in the context of particles like electrons. Participants explore how the spin state of a particle evolves over time, especially when subjected to external influences such as magnetic fields. The conversation touches on concepts from quantum mechanics, including eigenstates and the implications of measurements on spin states.
  • One participant questions whether a particle in a certain spin state remains in that state until another measurement is made, or if the probability of finding it in that state changes over time.
  • Another participant suggests that the answer depends on whether the initial state is an eigenstate of the Hamiltonian, indicating that stationary states do not change probabilities over time in the absence of external fields.
  • It is proposed that in the presence of a magnetic field, only states aligned with the field are stationary, while other components may change over time.
  • Participants discuss the implications of knowing the initial spin state, questioning whether it implies being in an eigenstate or simply understanding the combination of eigenstates with probability amplitudes.
  • Clarification is provided that any state of a spin-1/2 particle can be considered an eigenstate in some direction, and that the presence of a magnetic field causes the direction of spin to precess.
Participants express differing views on the implications of initial spin states and the effects of external magnetic fields on spin probabilities. The discussion remains unresolved regarding the nuances of how spin states evolve over time and the definitions of eigenstates in this context.
Participants acknowledge the complexity of measuring spin in different directions simultaneously and the role of external fields in determining stationary states. There is an emphasis on the conditional nature of the statements regarding spin states and measurements.
Turtle492
We've been covering quantum spin lately in lectures and I'm a little confused about the time-dependence of it.
Basically what I want to know is - if you know that a particle (let's say an electron) is in a certain spin state (say it's spin-up) at one point, if you come back and look at it again some later, will it still be in the same spin state?
We've done about Stern-Gerlach filters and at the time we were taught that if you select only particles that have Sz = +h/2 and then put it through another identical Stern-Gerlach filter, all of the particles will come through, because they all still have Sz = +h/2, since you haven't measured any other components of spin.
But then last week we were learning about the time-dependence of spin, and they said that if we start in a definite value of Sx, the probability of finding it in Sx some time later varies with time, so that the probabilities of the particle being in spin-up or spin-down states oscillate with time.
So now I'm a bit confused as to whether starting in a certain spin state means that the particle will stay in that state until you measure another component, or if the probability of finding it in that state changes with time. Any clarification would be greatly appreciated.
It depends if the starting state is an eigenstate of the Hamiltonian (aka stationary state). For example, if the particle is all by itself in the absence of a magnetic field, then the probabilities for finding the particle spinning in different directions will not change. However, if there is an external magnetic field, then only those states that correspond to particles spinning parallel to the field will be stationary states.
So if we had a magnetic field in the z direction, the spin in the x and y directions can change in time but the z component can't?
Also, does saying 'we know the initial spin state of the particle' mean it must be in an eigenstate, or does it just mean we know how the eigenstates combine with the probability amplitudes and everything?
Yes. Well, of course you can't measure the spin in different directions at the same time. The probability that the spin will be up in the z-direction won't change but the probability that it will be up in the x and y directions will change.
It's actually the same thing. Any state of a spin 1/2 particle is an eigenstate of spin in some direction. If you turn on a magnetic field, that direction will precess around the field, keeping it's angle with the field constant.
  • · Replies 17 ·
  • · Replies 32 ·
