Determination of Caffeine in Moutain Dew
The discussion revolves around the determination of caffeine concentration in Mountain Dew through a spectrophotometric analysis experiment. Participants explore the calculations involved in converting measured absorbance values to caffeine concentration, particularly in relation to the dilution of the sample.
  • One participant describes an experiment where they diluted a 4 mL sample of Mountain Dew to 100 mL with HCl and measured absorbance to determine caffeine concentration.
  • Another participant questions whether the caffeine amount calculated was based on the 4 mL sample, suggesting that this would affect comparisons to the total caffeine in a 2 Liter bottle.
  • A different participant proposes that if the caffeine concentration is known for the diluted sample, it can be used to calculate the concentration in the original sample before dilution.
  • One participant provides an example calculation, indicating that if a diluted sample shows a concentration of 6 mg/L, the original sample would yield a higher concentration based on the dilution factor.
  • Another participant acknowledges a misunderstanding in their calculation approach, realizing the correct method involves multiplying by the dilution factor rather than dividing.
  • A final comment emphasizes the importance of unit analysis in determining the correct calculations.
Participants express differing views on the correct approach to calculating caffeine concentration from the diluted sample, with some clarifying the relationship between dilution and concentration while others remain uncertain about the initial calculations.
There are unresolved aspects regarding the specific calculations performed and the assumptions made about the dilution process and its impact on the final concentration results.
MitsuShai
We did an experiment (link provided below), where we were to determine the concentration of caffeine in Mountain Dew. We made 3 standards and measured their absorbance along with the unknown (the mountain dew sample) and we graphed these results to find the concentration of caffeine in Mountain Dew. I wanted to compare this with the amount of caffeine in a 2 Liter Mountain Dew bottle (which was the sample used in the experiment).
I only had to take 4 mL of the same of soda, which was diluted to 100 mL with 10 mL of HCl, so I thought I just had to multiply the concentration that I got by 100 mL to get the mg of caffeine, but I didn't get 310 mg of caffeine (which is the amount of caffeine in Mountain Dew), instead I got a really small number. How do you calculate the mg of caffeine from the concentration (mg/L)?
http://www.mnstate.edu/marasing/CHEM380/Labs/380PLABL/Spectrophotometric%20Analysis%20of%20a%20Mixture%20%20Caffeine%20and%20Benzoic%20Acid.pdf
Haven't you calculated amount of caffeine in 4 mL?
So I can't compare it to the caffiene in a 2 Liter bottle, right?
If you know how much caffeine is on 4 mL, you can easily calculate how much is in 2 L.
From the information you posted it is not clear what you did and what you calculated. Procedure calls for measurement of concentration in diluted sample, so I guess the number you have is concentration AFTER dilution. This is not the same as in the original drink.
Hey, I did that experiment too a long time ago. Let me see if I can add something without getting into trouble:
Say you take 2ml of Dew and dilute it to 100ml and you run your sample against all the standards and you come out with a value that says in that 100 ml sample, you have 6 mg/l of caffeine. So wouldn't that mean in the original 2ml sample of Dew that would be 50 (6)=300 mg/l since you diluted 2/100?
Oh duh that's how you do it, I was thinking of multiplying the sample by (2/100) instead of (100/2).
Thank you so much.
Unit analysis tells you what to do... multiply or divide.
40K
14K
21K
