Conceptual quest on standing wave
The discussion centers on the conditions required for the formation of standing waves in a one-dimensional string wave, particularly focusing on the necessity of the string length being an integral multiple of the wavelength. Participants explore the implications of fixed endpoints and the behavior of waves upon reflection.
  • One participant questions why the length of the string must be an integral multiple of the wavelength for standing wave formation.
  • Another participant suggests that standing waves can form without the string length being an integral multiple of the wavelength, explaining that two superimposed waves of equal wavelength traveling in opposite directions can create a standing wave.
  • A participant elaborates that for a standing wave on a string fixed at both ends, the points of fixation must be nodes, leading to the conclusion that the string length must be an integral multiple of half the wavelength.
  • There is a query about the implications if the ends of the string were at maximum amplitude instead of zero amplitude, questioning the necessity of zero amplitude nodes at the endpoints.
  • Another participant responds that fixed endpoints require the amplitude at those points to be zero, reinforcing the concept of nodes at the ends of the string.
Participants express differing views on the necessity of the string length being an integral multiple of the wavelength for standing wave formation. Some argue that it is essential due to the fixed endpoints, while others suggest that standing waves can exist under different conditions.
The discussion includes assumptions about wave behavior and the nature of fixed endpoints, which may not be universally applicable. The exploration of standing waves is limited to the context of a one-dimensional string and does not encompass other wave phenomena.
PrakashPhy
How can we predict whether, a wave ( say a one dimensional string wave) traveling in any direction (say +x) after reflection from the fixed end, forms a standing wave in the medium or not (here string)?
I do not understand why the length of stirng should be integral multiple of wavelength( lymbda) for the formation of standing wave.
Please help me.
Hi PrakashPhy! :smile:
(have a lambda: λ :wink:)
Draw a wave, cut it at any point, and turn one of the bits round to fit on top of the other bit (with or without reflection) …
you'll quickly find that you can't match the two bits unless you make the cut at a top middle or bottom position. :wink:
PrakashPhy said:
I do not understand why the length of string should be integral multiple of wavelength for the formation of standing wave.
Please help me.
Your intuition is correct. Standing waves, in general, do not require string lengths to be integral multiples of wavelength.
When any sinusoidal wave is reflected back on itself from a single reflecting surface or point the result is two superimposed waves of equal wavelength traveling in opposite directions. The two superimposed waves will always sum to give a standing wave.
The amplitude of the sum of the two waves at the exact reflecting point is zero.
The amplitude of the sum of the two waves rises up to a maximum at one quarter wavelength from the reflecting point, drops down to zero again at half a wavelength from the reflecting point ... and so on.
The standing wave pattern extends for whatever overall distance the two waves continue to overlap, with zero amplitude nodes at regular half wavelength intervals.
This will occur for any wavelength.
In the special case of a piece of string fixed at each end the thing that makes a difference is that the string is fixed at two points, not just one point. For a standing wave to be maintained with two fixed points both those points must be zero amplitude nodes.
As described above, the distance from node to node in a standing wave is half the wavelength of the original sinusoidal wave. Therefore if the string is fixed at each end the length of the string must be an integral multiple of that distance.
What happens if two ends are at max amplitude (sum of either amplitudes) rather than zero. I mean why should the ends be at zero amplitude to "maintain" the standing wave pattern?
The same as if there were nodes at each end. We still have a double constraint and the possible wavelengths of standing waves are 2L/n in which L is the string length and n = 1, 2, 3... . This what you get for sound waves in a pipe open at each end - a so-called 'open pipe'! If there'e a node at one end and an antinode at the other (as for sound in a pipe closed at one end and open at the other - a 'closed pipe'), it's easy to see that the possible wavelengths are 4L, 4L/3, 4L/5 ... .
Because the ends are "fixed." Meaning whatever else happens to the string, the ends stay at their original positions, hence the wave amplitude at the ends has to work out to be zero.
  • · Replies 16 ·
  • · Replies 27 ·
