Solving the Problem: Calculating the Tension in a Sagging Wire
  • Thread starter Thread starter Freeze
    Tension Wire
The discussion focuses on calculating the tension in a sagging wire caused by a bird landing on it. The scenario involves two telephone poles spaced 50.5 meters apart, with a 1.40 kg bird causing a sag of 0.203 meters. The initial calculation for tension yielded 1708.35 N, but the user realized the error stemmed from neglecting the angles involved in the problem. Correctly accounting for these angles is crucial for accurate tension calculations in physics problems involving sagging wires.
  • Understanding of basic physics concepts, particularly tension and forces.
  • Familiarity with trigonometry, specifically the use of right triangles.
  • Knowledge of weight calculation using gravitational force (Weight = mass × gravity).
  • Ability to apply the Pythagorean theorem in practical scenarios.
  • Study the principles of tension in cables and wires in physics.
  • Learn about the application of trigonometric functions in solving real-world problems.
  • Explore the concept of static equilibrium in physics.
  • Investigate how to calculate forces in systems involving multiple angles and components.
Students studying physics, engineers working with structural designs, and anyone interested in understanding the mechanics of tension in cables and wires.
Freeze
Ok this is the problem
The distance between two telephone poles is 50.5 m. When a 1.40 kg bird lands on the telephone wire midway between the poles, the wire sags 0.203 m. How much tension does the bird produce in the wire?
This is what I did
I divided 50.5/2 = 25.25m (to get length of one leg)
The other leg is = .203 m
So, Length of Hypotenuse = 25.2508
Weight of the bird = (9.81 * 1.40) = 13.734 N
Now to solve the problem I did the following
(Weight of the bird/ the distance of the wire sagged) * the hypotenuse
To get the tension
so, the tension is = 1708.35 N
But this is not the right answer, so can anyone tell me what I am doing wrong?
Yep got it.. I don't know why I was ignoring the angles.
Thx.
9K
  • · Replies 19 ·
