Troubleshooting Matlab Loops: Discovering a Simple Solution | Get Help Now
  • Context: MATLAB
  • Thread starter Thread starter mikaili
    Loops Matlab
The discussion addresses a common issue in Matlab loops related to floating-point precision errors. Specifically, when using the loop structure for s=0:0.1:1, the variable s can accumulate rounding errors, leading to non-integer values when calculating the index for array V. This occurs particularly at s=0.6, where the expression 10*s + 1 results in a value like 6.99 instead of the expected 7. The root cause is the binary representation of decimal fractions, such as 0.1, which cannot be represented exactly in binary format.
  • Understanding of Matlab programming syntax and structures
  • Familiarity with floating-point arithmetic and precision issues
  • Knowledge of array indexing in Matlab
  • Basic concepts of binary representation of numbers
  • Research Matlab's round function to handle floating-point errors
  • Learn about Matlab's eps function for machine precision
  • Explore techniques for avoiding floating-point errors in numerical computations
  • Investigate the differences between decimal and binary number systems
Matlab programmers, data analysts, and anyone working with numerical computations who needs to understand and troubleshoot floating-point precision issues in their code.
mikaili
I have recently found a silly problem with Matlab loop
try the following simple program :
>> clear all
>> for s=0:0.1:1
>> V(10*s+1)=s;
>> end
it will get into trouble when s reaches 0.6
would anybody please check and let me know the result
I don't have Matlab, so I can't check to see what happens. I suspect that you run into a problem with the index of the array V not being an integer.
If this is the problem you're having, the reason it's happening is that certain numbers that have a nice, neat representation in decimal fractions aren't represented exactly as binary real numbers. One decimal fraction in particular that has this problem is 0.1.
A binary fraction as used in many programming languages uses powers of 1/2. For example, you could think of 3/4 as being represented as .11, meaning 1 * 1/2 + 1 * (1/2)^2. The actual representation is a bit more complicated, but this is the idea.
Just as 1/3 requires an infinite number of decimal places to represent, so does 1/10 as a binary fraction. Since computers don't have an infinite amount of storage available, what you get for the representation of 1/10 in binary is a number that is close, but not exactly correct. The problem gets worse if you add 1/10 to itself a few times, such as what happens in your loop. Apparently, by the time s is .6, the accumulated error is enough so that 10*s + 1 comes out to something like 6.99 or so, instead of 7, and then Matlab complains because you are trying to access an array with an index that isn't an integer.
Thanks Mark44 , Your answer was convincing . Actually when I checked s-fix(s) it was a number in the range of 1*10^-16
