The sum of torques is not the sum of torques?
  • Thread starter Thread starter flyingpig
    Sum Torques
The discussion revolves around the concept of torque in a physics problem involving rotational dynamics. Participants are examining the application of torque about different axes, specifically the center of mass and the rim of an object, and how this affects the calculations and understanding of the problem.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants express confusion about why only one torque is considered at a time in the solutions provided. Questions arise regarding the definitions of torque and the implications of choosing different axes of rotation. Some participants attempt to clarify the relationship between the gravitational force and the center of mass in relation to torque.
The discussion is ongoing, with participants seeking to clarify their understanding of torque and its application in the problem. Some have begun to grasp the concept that certain forces may not contribute to torque depending on the chosen axis of rotation, while others continue to question the reasoning behind the solutions presented.
Participants are working within the constraints of a homework assignment, which may limit the information available and the depth of exploration into the topic. There is an emphasis on understanding definitions and the physical implications of torque in different scenarios.
flyingpig
[PLAIN]http://img51.imageshack.us/img51/5193/48593149.jpg
Solutions
[PLAIN]http://img444.imageshack.us/img444/9900/78057474.jpg
[PLAIN]http://img84.imageshack.us/img84/8471/74918866.jpg
I don't understand the solutions at all, why do they only take consider one torque at a time? I know the Math works out, but I don't understand why at all
Part b)
Mg - T = Ma
R(Mg - T) = Iα
R(Mg - T) = ½MR²(a/R)
R(Ma) = ½MR²(a/R)
Ma = ½Ma
½Ma = 0
Also, for the second alternative answer, how come it says mg acting on the rim? I thought mg only acts on the center of mass.
Read and understand the answer. The first method says "Torque about the center of mass" and the second solution says "Torque about the rim". What do these mean?
Yeah, I don't know what that means, I mean it make more sense if it was the other way around.
What is the definition of a torque? Look in your textbook.
What way would that be?
I still don't understand, torque = r cross F
That r is the vector from the axis of rotation to the point at which the force is applied. When the axis of rotation is considered to be passing through the center of mass, what is the r vector for the gravitational force? When the axis of rotation is considered to be passing through the contact point on the rim, what is the the r vector for the tensile force?
No, my problem is the torque they used is only one of the torque acting, it isn't the sum of the torques acting on the body.
In both cases they are dealing with the sum of the torques. In both cases, one of those torques is identically zero.
Ohh okay I get it, the mg force is acting on the center of mass, which also happens to be the rotation axis and if we take that as the rotation axis, the tension will obviously have no torque, okay make sense
thanks you two
  • · Replies 22 ·
  • · Replies 21 ·
  • · Replies 18 ·
13K
