Register to reply
Physics-kinematics help-pellet and rifle
by MarcusB
Tags: helppellet, physicskinematics, rifle
Share this thread:
MarcusB
#1
Dec7-10, 03:40 PM
P: 1
An air rifle can be used to fire small metal pellets which have a speed of about 150m/s on leaving the rifle. When an absorbent material is placed some distance from the rifle, the pellets are observed to penetrate the material to a depth of 3 to 4 cm.
Design an experiment to investigate how the depth of penetration varies with the speed of the pellet with a diagram and describing how
a) the speed of the pellets may be measured
b)The depth of penetration into the absorbent material may be measured
c)the speed of the pellets may be changed ( assuming the pellets leave the rifle with a fixed speed.)
d)any safety precautions for experiment
The foll. is available together with standard college lab equipment:
mounted air rifle
connecting wires
stopwatch
power supply unit
light gates
electronic timer
rule
sheets of absorbent material (eg cork)
thin aluminum foil
expected results
Please help............i have no idea what to do and exams are soon
2. Relevant equations
3. The attempt at a solution
i guess the light pipes can be used to measure the speed of the bullet but how do you vary the speed?
can you use the foil to slow the bullet???
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
berkeman
#2
Dec7-10, 04:24 PM
Mentor
berkeman's Avatar
P: 41,109
Quote Quote by MarcusB View Post
mounted air rifle
connecting wires
stopwatch
power supply unit
light gates
electronic timer
rule
thin aluminum foil
expected results
There are at least two other ways to vary the speed of the bullet hitting the target. One involves the equation TE = PE + KE. What do you think that method would be? And does it suggest another method?
Register to reply
Related Discussions
Calculation of gain for pellet with some layers Nuclear Engineering 1
Pellet fired at angle question Introductory Physics Homework 10
Annealing before and after pellet formation Atomic, Solid State, Comp. Physics 3
Pellet on top of cylinder Introductory Physics Homework 4
