Solving Pressure Shooter Kink: Find Volume & Air Needed
  • Thread starter Thread starter mmartin
    Cylinders Volumes
The discussion revolves around calculating the volume of air needed to fill a pressure shooter cylinder to a target pressure of 100 psi. Participants explore the necessary equations and assumptions involved in determining the amount of air required, considering factors such as temperature and the molar mass of air.
  • One participant states the cylinder has a volume of 4,994.57 cubic centimeters and seeks to know how much air is needed to achieve 100 psi.
  • Another participant suggests using the ideal gas law (PV=nRT) and emphasizes the need for temperature and molar mass of air to calculate the required amount of air.
  • A question is raised about the method for calculating the molar mass of air based on its composition.
  • It is proposed that ignoring other gases in air is acceptable for the molar mass calculation, and a follow-up question asks if achieving exactly 100 psi is necessary.
  • Concerns are expressed regarding the mechanism for pumping air into the cylinder and the structural integrity of the container at 100 psi.
  • A participant expresses confidence in the container's strength and discusses the use of a compressed air tank, noting that the air pressure does not need to be exactly 100 psi but can vary slightly.
  • A suggestion is made to assume 100 psi absolute and calculate the required volume of uncompressed air needed to achieve this pressure in the cylinder.
  • Another participant challenges the adequacy of the proposed air volume, stating that a 100 psi compressed air tank may not provide enough air to reach 100 psi in the cylinder and suggests that the tank pressure needs to be higher.
Participants express differing views on the adequacy of the proposed air volume calculations and the necessary tank pressure to achieve the desired cylinder pressure. There is no consensus on the final approach or calculations needed.
Participants mention the importance of temperature and the need for unit conversions in calculations. There is also a discussion about the implications of tank pressure and the final volume when air is allowed to equilibrate.
mmartin
I've made this pressure shooter for school, but I can't quite figure out this kink. If the cylinder has a volume of 4,994.57 cubic centimeters, and I plan on filling it with 100 psi of air (I want to maximize the pressure) how much air am I going to need? I could just flow it in, but I need to know how much to buy to shove it in (without blowing the container). Any help would really be apprecaited, I want to get his ready in a month or so and the schedule is looking down right now.
Chemistry news on Phys.org
You will need temperature and the molar mass of air. Use the equation [itex]PV=nRT[/itex], where P is pressure in kilopascals, V is volume in L, n is moles of gas, R is the universal gas constant (8.314), and T is the Kelvin temperature. Make the appropriate unit conversions. I say you need molar mass of air because I'm assuming you want to know the mass of air you need to bring the pressure to 100 psi.
How do you find Molar mass of air?
Is it corect to say 70/100*28 + 30/100*32 where 32,28 are molar masses of oxygen,nitrogen and 70,30 their % in air?
If you ignore the other gases present, yes, you can do it that way. You could look it up somewhere as well. Mmartin, is it important that you have the air at exactly 100 psi, or just something close to that?
More importantly, what mechanism do you have for pumping ("shoving") air into your cylinder ? Do you have a compressed air tank with a p > 100 psi pressure regulator ? Do you know for sure that your container won't fracture at 100 psi ?
I am fairly sure (which is a great assurance) that the container will not fracture at 100 psi, it's pretty strong. I will be using a compressed air container, I'll have to check later if it reads x>100 psi. No, the air does not have to be exactly at 100 psi, but close, plus or minus 5 psi. I originally tried the PV=nRT equation, but I couldn't figure out the Pressure to Temp ratio. That said, still trying to find out how many gallons. This was one man's suggestion, how does it check out, I think it just about answers it.
"Assume 100psi absolute. 100/14.7 is about 6 to 7, so you should need 6 to
7 times 1.2 gallons of uncompressed air to be compressed to get your
cylinder up to 100psi-absolute. For 100psi gauge, you need about 1
additional gallon of uncompressed air."
I would say that that would be the logical approach? Any scientific qualms?
Thanks.
No...none. As far as the calculation is concerned, that's fine. However, if you buy a 100 psi compressed air tank with the equivalent of 1.2*7 gallons of uncompressed air, you will not be able to get your container up to 100 psi...you'll only get to about 50 psi.
Either the compressed air should be at 200 psi, or you'll need more air. I think they specify the pressure and the volume at that pressure. So, you can use the PV relation, as before, to determine what will work. But keep in mind that if you let the tank equilibrate with your container (which will be required if the tank pressure is not much more than 100psi), the final volume is the sum of the two volumes.
  • · Replies 45 ·
