Why is unbalanced caused by a centrifugal force?
  • Thread starter Thread starter koolraj09
    Rotating
The discussion revolves around the concept of centrifugal force and its role in the balancing of rotating masses. Participants explore whether centrifugal force is a real force or a pseudo force, particularly in the context of non-inertial frames of reference, and how this relates to the unbalance of rotating shafts.
  • One participant questions the nature of inertia force and whether centrifugal force is a real force, suggesting that it only appears in non-inertial frames of reference.
  • Another participant argues that centrifugal force does manifest in reality, especially when analyzing forces within a vehicle turning in a circle, implying that it is useful in certain contexts.
  • A participant describes a scenario involving a rotating shaft, stating that if the shaft is unbalanced, its center of gravity is not aligned with the axis of rotation, leading to the influence of centrifugal force as described in textbooks.
  • Another participant counters that the shaft remains unbalanced even when viewed from a non-inertial frame, emphasizing that the connection to the axle experiences a force due to the unbalance, which contradicts the idea of it being perfectly balanced.
  • It is noted that if the connection between the shaft and axle were to break, the shaft would not remain in place, further supporting the argument that it is unbalanced.
Participants express differing views on the nature of centrifugal force and its implications for balance in rotating systems. There is no consensus on whether centrifugal force is a real force or merely a useful concept in non-inertial frames, and the discussion remains unresolved regarding the implications of these perspectives on the reality of unbalanced systems.
Participants highlight the complexity of analyzing rotating systems from different frames of reference, with unresolved questions about the definitions and implications of centrifugal force and inertia force.
koolraj09
Hi guys.
Firstly I want to know what is inertia force? Is it a real force?
Then regarding balancing of rotating masses, why is unbalanced caused by a centrifugal force? I mean I've learned in my intermediate that centrifugal force is a pseudo force and it is only to be taken into consideration when we are in non inertial frame of reference. That means centrifugal force(& indirectly unbalance) will come into picture only when we're in non-inertial frame of reference. But this doesn't happen in reality. What is the reason behind this paradox?
Can anyone explain?
Thanks.
hi koolraj09! :smile:
it does happen in reality …
in reality, we often prefer a https://www.physicsforums.com/library.php?do=view_item&itemid=87"
for example, in any vehicle turning in a circle, calculating forces within the vehicle is far easier in a rotating frame :smile:
(and, by coincidence, I've just written in https://www.physicsforums.com/showthread.php?p=3028090" in a rotating frame)
i don't understand :confused:
Hi tiny tim.
What I mean to say is consider a rotating shaft. If the shaft is unbalanced it means that it's c.g. is not at the axis of rotation. Then comes into play our centrifugal force...this is quoted by most of the textbooks.
So what I really want to ask is that in reality the shaft is really unbalanced. But if we look from non inertial frame of reference then shaft is unbalanced because centrifugal force is there in this case. Now if we look at the shaft from an non-inertial frame of reference then it's perfectly balanced. But it's contradictory to reality.
no!
the shaft is not balanced, because the axle can feel the shaft tugging at it … if the shaft came loose from the axle, it would fly away (instead of continuing to rotate on the spot)
in the https://www.physicsforums.com/library.php?do=view_item&itemid=87" from the axle on the shaft, radially inward from the c.o.m.
… it balances the centrifugal force, keeping the shaft in equilibrium
(if the c.o.m. was at the axle, the shaft would be balanced, and there would be no reaction force)
in the inertial frame, there is the same reaction force
… it has no force balancing it, and so the c.o.m is forced to accelerate towards the axle, resulting (obviously! :rolleyes:) in a rotation
in either frame the shaft is unbalanced …
if the connection is broken, the shaft will fly off​
  • · Replies 18 ·
  • · Replies 93 ·
  • · Replies 40 ·
  • · Replies 114 ·
