Is entropy 'S' measured on some fixed scale?
  • Thread starter Thread starter jackson6612
    Entropy Scale
The discussion revolves around the measurement of entropy 'S' and whether it is on a fixed scale, including inquiries about maximum values and examples of entropy changes in chemical reactions. Participants explore theoretical implications and comparisons to other scales, such as Moh's hardness scale.
  • Some participants question whether entropy is measured on a fixed scale and if there is a maximum value associated with it.
  • Examples of entropy increase are discussed, with evaporation cited as a scenario where a system settles at a higher energy state.
  • There is a comparison made between entropy and temperature, noting that while temperature has a minimum value, it does not have a maximum.
  • One participant suggests that there may be a maximum amount of entropy in a given space, referencing black holes.
  • A formula for black hole entropy is presented, indicating that there may not be an upper bound on black hole entropy density.
  • The Moh's hardness scale is discussed, with participants noting its arbitrary nature and questioning how to rate materials that exceed the established scale.
  • Some participants argue that hardness and entropy are fundamentally different properties, with entropy being well-defined in statistical mechanics.
  • There are theories mentioned regarding the universe potentially reaching a maximum amount of entropy, though uncertainty remains about their validity.
Participants express differing views on whether entropy has a maximum value and how it relates to other measurement scales. The discussion remains unresolved regarding the implications of entropy in various contexts.
Limitations include the lack of consensus on the maximum value of entropy and the definitions of scales being discussed. The relationship between hardness and entropy is also noted as a point of contention.
jackson6612
I'm not a science student. Therefore, please keep your replies as simple and straightforward as possible so that your help can be fully appreciated. Thanks.
Is entropy 'S' measured on some fixed scale? If yes, then what's the maximum value?
When oxygen and hydrogen react to form water, the overall entropy decreases at the expense system losing energy and setting at lower energy state (exothermic reaction). Could you please give me an example where entropy increases and the system settles at somewhat higher energy state?
Please help me. Thanks.
Chemistry news on Phys.org
Entropy is measured on a fixed scale, but I don't see why that would imply that there's a maximum value.
This occurs in evaporation.
Thanks a lot, Mapes. I have read Moh's, I think it's for hardness measurement, has fixed upper and lower values.
Temperature is also measured on a fixed scale, but has no maximum.
Hi Red
Thanks. You are correct. Temperature has only minimum value, no maximum. I think on Moh's scale diamond is given the maximum hardness. Don't remember about the object given the least hardness value - perhaps, it's graphite.
Just out of curiosity, is it not true that there is a maximum amount of entropy that you could have in a given space? Like in black holes or something?
The black hole entropy is given by
[tex]S_{BH}=\frac{A}{4}[/tex] expressed in units of Planck area.
if we assume that entropy is distributed evenly throughout the hole (it may not be).
Since [tex]A \propto V^{\frac{2}{3}}[/tex], there is no upper bound on the black hole entropy density.
jackson6612 said:
Hi Red
That's just the definition of the scale. Diamond is set to 10 and talc is set to 1. That doesn't mean there aren't materials softer than talc or harder than diamond. (Although there's a limit to the hardness of a material from both a discovery and theoretical material science point of view)
Thanks, Dav.
If there is a material twice harder than diamond, then how would you rate its hardness on Moh's scale? Please guide me. Thank you.
jackson6612 said:
Thanks, Dav.
You wouldn't. The Mohs scale is just an arbitrary ranking, not a true scale with well-defined spacing. You could give your material a Mohs value of 11, if you wanted.
jackson6612 said:
Thanks, Dav.
It's purely a comparative scale (an "ordinal" scale) where certain baseline minerals were given hardness values from 1 to 10. Then you could compare any given material to these and if it was harder than a 7, but softer than an 8 you could say it's a 7.5. If something is harder than diamond you would just say it's >10 on the Moh's scale. The hardness increase between each step on the scale is not constant so you can't really say "if something is twice as hard as 10 it should have this hardness" http://en.wikipedia.org/wiki/Mohs_scale
There are other scales of hardness that are more useful and are based on an indentation measurement. Basically you have a standard indenter that's pushed into a specimen at a standard load, and a hardness value is determined from the size of the resulting indentation.
In any case, you shouldn't compare hardness to entropy since the two properties are completely different. Hardness depends on how you make the measurement and it's not really a true property of a material.
Entropy, however, is well-defined for a particular system. Looking from a statistical mechanics point of view, entropy involves nothing more than counting the possible states of a system. There is no subjectivity in counting the states. You count them and then an equation relates that number to the entropy of the system.
As you said, there is a lower bound to entropy and that is 0. However, you can imagine that in any system with entropy S you can always do something to the system to increase the entropy.
There are theories that say that the universe as a whole can potentially reach a maximum amount of entropy, but I don't know anything about these or how likely they are: http://en.wikipedia.org/wiki/Heat_death_of_the_universe
Dav, thank you very much. You've done a good job. By the way, I rarely refer to Wiki articles because they're are possibly written for science persons, not for a layman like me. Or, it is just that I'm a qualified stupid.
