Capacitor Disconnected from Battery, changing distance
  • Thread starter Thread starter jeffc313
    Battery Capacitor
A parallel-plate capacitor, once disconnected from the battery, retains its charge when the plates are moved closer together. The charge on each plate remains constant because the disconnection prevents any flow of charge. The confusion arises from the relationship defined by the equation Q = CV, where C is the capacitance and V is the voltage. In this scenario, since the capacitor is isolated, the charge does not increase despite the change in distance between the plates.
  • Understanding of parallel-plate capacitor principles
  • Familiarity with the equations C=Q/V and C=ε₀ * A/d
  • Knowledge of electric charge behavior in isolated systems
  • Basic concepts of capacitance and voltage relationships
  • Study the effects of changing plate distance on capacitance in isolated capacitors
  • Explore the implications of charge conservation in electrical circuits
  • Learn about the behavior of capacitors in series and parallel configurations
  • Investigate the impact of dielectric materials on capacitance
Students studying electromagnetism, electrical engineers, and educators seeking clarity on capacitor behavior in isolated conditions.
jeffc313
1.A parallel-plate capacitor is fully charged and then disconnected from the battery. The plates
are then moved closer together, how does the charge on the plate change
it needs to be stated whether the charge on each plate increases, decreses or stays the same
C=Q/V, C=epsilon_0 * A/d
when the capacitor is disconnected, the charges cannot flow. So each one should stay the same, right? The solution for this exam problem that was on last years final says that it should increase. This doesn't make sense to me. Is the solution wrong, or am I wrong?
Welcome to Physics Forums.
I'm pretty certain you are correct, for exactly the reason you give.
Q = CV, so the charge would increase if the capacitor remained connected to the battery (V=constant, and C increases).
It sounds like the professor got confused about what the question was asking.
  • · Replies 18 ·
